ABS Light resolution
Since I bought this truck about 8 months ago I have had the three amigos plus the brake light was on. Upon reading nearly everything on the subject I replaced the shuttle valve, but not the falcon gaskets as there was no obvious leakage.
I replaced much of the brake fluid as well.
Long story short, all four lights remained. A generous board member here sent me his ABS amigo. I pulled codes and found the attached.
1.--Current Faults---->
Active Faults:
None
Logged Faults:
015:Pump fail pump running when not On
022:ECU Gnd or Reference Gnd bad
045:Rear Left sensor output low
Rear Left Sensor Bad Output
114:Shuttle Valve Electric Failure
<-END Faults
..--Previous Faults--->
Active Faults:
None
Logged Faults:
040:Pump relay open circuit
My point is that the codes indicate speed sensors among other faults. And I did not, knock on wood, replace or repair them.
So, a couple days later, no codes. Hopefully, that continues.
Active Faults:
None
Logged Faults:
<-END Faults
Active Faults:
None
Logged Faults:
Update: Drove it for a while in the snow, got the traction control to engage. The TC light went on momentarily. Otherwise, amigo free.
The stored codes are:
Active Faults:
None
Logged Faults:
<-END Faults
Active Faults:
None
Logged Faults:
<-END Faults
If I understand correctly, I need to do the bypass, is that accurate?
Thanks,
Active Faults:
None
Logged Faults:
<-END Faults
Active Faults:
None
Logged Faults:
<-END Faults
Thanks,
marlymarl
05-28-2011 10:34 PM
Second2None
12-06-2010 05:26 PM
johnkbl
01-13-2009 08:54 PM
Surfin Elvis
06-23-2005 11:08 PM
