ABS MODULATOR FIX (NO more SVS fault)
#241
well Ironically I sort of have been .. but I think my last fiasco helped me solve issue! several of our esteemed colleagues made comment of my odd situation where Id get brake light and 3 amigos when i put on my high beams or left turn signal with lights on... after going through 2 batteries in a couple of years i put in an optima red and the 3 amigos have left the building! now recently they came back and I think I know the issue... alternator! i think over time my battery is not getting its full charge... I'm going to put my battery on a charger and test that theory... if it is in fact the case Ill go get one of those range rover 150amp alternators and see if that helps! i went 6 months with no amigos...now they have returned but only with same situation... lights at night with left turn signal lol
#242
#243
#244
Did the hubs come with new ABS sensors (I'm guessing yes, but want to make sure). If they did, I'd follow the wiring all the ay and make sure it's in good condition. If the insulation is compromised it can ground against the metal and cause the ABS system to act squirmy.
I am going to source a SLABS ECU and put that in.
Do you have to have the truck reprogrammed to change the SLABS ECU?
#245
write up on abs repair.
How do you get the writeup on the OBS system repair??
Thanks
Henry Underwood
New to Forum.
Thanks
Henry Underwood
New to Forum.
Moderator edit: updated link: ABS Mod - LAND ROVER CLUB V.I.
edit: most of the original info is gone, but a couple of guys put up some decent info.
figured it would be helpful to put the good stuff together and not have to look through the dead links. the below link will get you there and if anyone has any additional info, please share....,dusty
https://landroverforums.com/forum/di...abs-fix-71905/
Well everyone, here is MY ABS Modulator fix write up.
landroverclubvi.com
Let me know what you all think....
landroverclubvi.com
#247
Nuts! The front left wheel speed sensor that was in there was actually fairly new. So I put that on the right front wheel, and lo and behold the symptoms of TC going off intermittently, but not throwing a code, switched to the right side.
Oy!
I have a new speed sensor for the right side coming this week, and will try to get that in this weekend.
#248
The adventure continued. I replaced the front left wheel speed sensor after confirming with another SLABS ECU that mine was good. Immediately the right wheel speed sensor threw a code and turned on the three amigos.
Oy!
Oy!
good grief.
is it possible not having the bracket behind the hub is causing it?
#250
I've done this fix, worked great for me. What I found strange is that that the yellow/green wire doesn't ohm out to either pin on inside of the module, but the black wire (if I recall it was black) next to it does. So it seems like it shouldn't work but it does. I had also run an extra ground wire to the separate ground plug on the module.
