Added seafoam for sticking lifter
IF you really want to get rid of SOME of the noise, this will work:
1) put in a 180 degree thermostat. Will lower the engine temps and then less parts which are loose due to higher heat.
2) Radiator - maybe. If (1) does not help.
3) Put in thick regular OIL - like 20W-50W for the summer. The thick oil will pad the clearances for the lifters and increase oil pressure for everything else.
I am at 104,000 and my motor is fairly quiet.
stuff
Im running Rotella T 15/40. No overheating, no engine light ever.
I havent checked oil pressure yet. As far as pulling the plugs one at a time, how exactly is that done, sounds like it would hurt the motor... And if I pull a plug and the noise goes away what does that mean?
Also if I was to check the oil pressure what info would it give me? Thanks
when I purchased my rover I noticed that after a long drive I was getting a nasty tick. after purchasing an ultra gauge I saw my problem, I was running 114 degrees. Water wetter, rotella 15-40, 180 stat, lucas oil additive, and mine runs quiet and about 185 degrees. so if you are running hot you could have a viscosity issue... may have nothing to do with your problem, but it is a viable solution if your problem is a viscosity issue.. if it is a lifter or a sleeve, then happy wrenching!
