Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > Discovery II
Register Forgot Password?
Old 01-30-2012, 10:09 AM
Junior Member
Default Advice on 99 discovery
Hello,
My gf has decided that her next car shall be a land rover discovery. Shes set her heart on a 99 with 170XXX miles.
It's an SE7, black, clean interior. We test drove it, and I didn't hear anything to alarm me, other than what sounded like a loose accessory belt. There was also a pinhole leak in the muffler, but the exhaust smelled fine, no sweet coolant or burning oil smell. The front differential did have a pretty good oil residue on it, and so did the oil pan.
My question is, are these things normal, or red-flag raising, run away, don't touch with someone else's 10 foot pole, deal-breaking problems?
Also, I found another 99 around my area with 97XXX miles.
Second question is which would be a better buy / have less chance of having something deathly wrong with it? The rover that has made it to 170k or the one just entering the problem range?
Thank you for any feedback and wisdom that you provide.
I'm just very hesitant, and my gf is very independent, and I can't seem to convince her to get a Toyota (don't hate me...). She's coming from 2003 Ford exploder that's dying due to a blown head gasket, so I question how wise is it to switch to another car that has HG issues.
Thank you very much,
Vlad
Old 01-30-2012, 10:19 AM
Send a message via Skype™ to Disco Mike
First, if you are close to Redwood City, there is a great Rover shop called Cerrones, they also have a forum called the Land Rover Repair Forum, the LRRF. Might want to check with them on local issues.
Also, if you want all your questions answered, PM me your tele number and I'll call you.
__________________
Mike
Retired service manager. Member of the Solihull Society, NCLR club, SCLR and Santa Barbara 4 Wheelers.
99 D2, 3" lift, CDL with a Detroit and T.T. lockers, H.D. axles, 4:11 gears, Custom front and rear bumpers, sliders, Warn winch, and 5 HID's.
To Download the RAVE Manual, follow this link http://www.landroverresource.com/
Rover Radio issues or IPOD Adapters http://home.valornet.com/splacket/index.htm
Need Parts?
paulgrant@mac.com, or 203-770-1699
willtillery@roverguy.com, or 434-251-9331
Paul PTSchram 260-804-0458
PM Marty(Drillbit)[url]http://www.landroversonly.com/forums...o=newpm&u=5940
British Parts of Utah, http://www.bputah.com/
Lucky8, http://lucky8llc.com/
Old 01-30-2012, 10:22 AM
Senior Member
Either Rover could have more problems around the corner, but obviously the high miles one may be closer to it, or may have had some things done already. You would be wise to invest an hour of a mechanic's time to check out the vehicle. If what you heard while driving was a squeak or a chirp, like a loose belt, that could also be a front drive shaft about to split, and then spear a big hole in the transmission. A serious issue for D2 owners. Rebuild write up in our tech section. With either DIsco, if your will be helping her with the service work, you will have a new hobby. Discos are not just tires and oil at WalMart kind of vehicles.
__________________
Old 01-30-2012, 10:32 AM
Junior Member
Mike, I will be taking you up on that shortly.
SB, I should have clarified, I heard the noise when it was idling, so that leads me to believe it was the belt, and not a front drive shaft.
Thank you both.
Old 01-30-2012, 11:38 AM
Senior Member
Unless it has extensive records of upkeep and repair, id steer very very clear of that 170k. head gasket job, new water pump, front drive shaft, o2 sensors, tranny and axle fluid changes, oil changes... no paper no deal. id buy it for spare parts only unless you want a rebuild! id go over it with a fine tooth comb at those miles from wheel seals, to front end play, suspension, rain leaks under glove box and at sunroofs, abs solinoid leaks, power steering pump leaks/condition, rear valve cover gasket leaks, front cover leaks, bushings all around, brake lines, vac lines, check coolant condition/gravity, oil condition, brake rotors etc etc etc.
the 90k youd be good with standard inspection, but also look at drive shaft in particular... but if it hasnt been done, headgaskets probable in not to distant future, espcially if the previous owner used it offroad, towing or had a heavy foot.
__________________
Black 2000 Disco II
Factory brushguard
3" Terrafirma + s. damper
Terrafirma F/R Diff Guards
Terrafirma Fuel Tank Guard
D90 ujoint propshaft
Bosche Plat +4 + blu wires
Amsoil coolant/diffs/xfer
Shell Rotella + Filtermag
Rain X Repel wiper mod
DI CDL
285/75/R16 Guard Dog MT's
NO CEL OR AMIGOS
Old 01-30-2012, 12:26 PM
drowssap's Avatar
Senior Member
unless you have written proof that the 170k truck has had a ton of work, you need to treat it the same at the 90k unit. That is everything is due to be serviced or replaced.
Either truck is going to have a lot of 13-year old parts that will need replacing. I would plan on have a couple thousand set aside to for improvements and upgrates the first year.
__________________
00 Disco 4.0 80k miles SLS, ACE, 7 passenger 255x65x18: Repairs since 02/11 new intake, valve cover, head, timing cover, waterpump & oil sump gaskets, new timing chain & gears, water pump, t-stat, hoses, belt, new front drive shaft, Akebono pads, D&S rotors, SS brake lines, clutch fan, HMS completed.
90 RRC County
67 mustang GTA
73 Jeepster Commandos
69 Honda SOHC
71 HD FX
72 BSA Lightning
73 Honda SOHC
78 Honda SS
87 HD FLTP
2004 HD SE 103
He who dies with the most toys, WINS
Old 01-30-2012, 03:07 PM
dcarr1971's Avatar
Senior Member
X2
For example, at 97k if the 2nd truck hasn't had it's head gasket replaced already, then it will probably need one sometime in the near future. The same is probably true of the 170k truck as it's getting back around to that point again.
The '99s can be pretty exceptional values, but make sure you maintenance records, have the truck checked out by an independent Rover mechanic before buying it, remember how old it is, and be prepared to do lots of maintenance to keep it running properly.
__________________
Dave
Pittsburgh, PA
1999 Land Rover Disco II - 118k miles, Locking CDL from a D1, SD Rack, 3rd Row added, 255 85r16 BFG KM2's, TerraFirma 3" lift w/ TF +2 shocks, QT front diff guard, Southdowne rear diff guard, fuel tank skid...more to come...
1996 Disco I "Red" 5-Spd - 120k miles, 2" OME lift, X-Brake, just getting started...
Rave download: http://www.landroverresource.com/
Fort Pitt Land Rover Group
Old 01-30-2012, 03:17 PM
hilltoppersx's Avatar
Senior Member
edtatton
you're screwed either way. chicks should only drive defenders. at least that's what i think.
__________________
-Ed
99 DII, TF +2" HD & steering damper, TreadWright 265/75/16, ARB front, BritPart rear, Warn m8000 with synth, Columbia Overland gate panel & dual battery tray, Safari snorkel, RoverBones diff guards, RockWare sliders, DieHard Plat Deep Cycle, Chalkboard Headliner, CB, Wilderness Rack, 6 hella 700 ff's w 100w bulbs, 2 hella work lights
93 RRC TF track rod, tie rod & steering damper, TRW rims
Northeast Land Rover Club
www.nelrc.com
Tags
99, amigo, areas, discovery, end, ii, land, lights, location, o2, play, power, problem, pump, rover, sensor, steering
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
