Answer: Biggest tire 18in rims
A lot of people have had questions about this. I have a 2003 discovery with 18s and wanted to go with bigger than 255 55 that came with it. I don't have a lift and don't have the ACE. I was able to fit 265 65s on my truck with no issues. I went with the Toyo open country a/t, they are a 50,000 mile tire and are somewhat agressive. I can turn lock to lock and they do not rub at all. Make the land rover actually look like a off-road vehicle. Will post pics once it quits raining. Hope this helps some of y'all out
I put 275/70/18 ATs on my Disco with stock suspension (ACE, if that matters??). I had to pull the bottom of the front bumper forward a bit, and insert a wedge type object between the top of the bumper and the fender to hold it that way. Then used a dremel and cut a bit of the plastic trim on other various places. It drove fine like that for a while, just had a couple problems bottoming out. Installed 2" lift coils and now it drives great. Only problem is it can still rub on turn-lock, but I don't mind. I also need to install longer shocks now, as for the stock ones, whenever they reach max extension when driving it makes a racket and jolts the cabin.
