Anybody use Synthetic oil?
RE: Anybody use Synthetic oil?
I use the Mobil 5W40 truck & Suv but not for summer.
For summer I use the what is now called Mobil One Extended Performance 10W40.
They say it good for 15,000 miles I go 5,000.
On the old style motor that we have you can get a lot of build up on the
inside and oiling was not a high point for this V8.
You could do with less if you only keep a vehicle for a few years.
Synthetic oil. YES it is the only way to go. I use it in every thing I own. I use it in anything that has moving parts and I change it often. Synthetic oil is not susposed to brake down like other oils, but I am sure it gets just as dirty. I am not sure if it matters much which one you use. Synthetic is the only way to go if you care about your toys.
Regards Dennis
Regards Dennis
Thanks I appreciate the responses. I went to get some Power steering fluid yesterday cause i was sitting on the minimum reading with the truck off. In the manual it said there would be 2-caps mine only has 1 but it is a huge canister so I assume it is for the ACE[&:] Also it said to use Texaco PAS(Power Assist) I guess...and it should be amber in color. We looked for the cross ref @ Auto Zone and no cross ref for that or the GM one mentioned....Does it really matter?
