Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > Discovery II
Register Forgot Password?
Old 01-14-2012, 07:19 PM
94svt50's Avatar
Senior Member
Default bleeder screw leak.
Noticed an anti-freeze smell and when I popped the hood I saw antifreeze bubbling from the center of the bleed screw, how it came to have a hole in the center I have no idea. What are my options on this? does anyone know the thread size and if I could find a brass plug or something to thread in there?
thanks
__________________
'03 HSE7 112k driveshaft/headgasket/water pump/oil pump/all fluids akebone pads and new rotors and I have almost had it a year
'02 pathfinder 160k
'89 yota 4x4 251k
Old 01-14-2012, 08:13 PM
FightOnUSC79's Avatar
Senior Member
WEST.WEST.YALL John_R_Scott
There's a brass replacement you can purchase at the BMW dealership and the parts guy usually knows what you're talking about or you can scoop it up on eBay if you don't need the vehicle for a few days.
__________________
2004 Disco II SE 110K Miles on truck/48 on engine:
Rebuilt front drive shaft / mikes 60k service / new shoes / HG / 8mm STI wires / Akebono pads front and rear / New Rotors all around / OME Steering Stabilizer / Ultra Gauge
In the future: HLC Front and rear bumpers - OME Suspension - Safari Rack with Lights - Let the saving begin
Arizona Land Rover Owners Member AZLRO.org
Fight On USC!
Old 01-14-2012, 08:16 PM
94svt50's Avatar
Senior Member
Thanks, Do you know what the part number is?
Old 01-15-2012, 01:02 AM
Senior Member
Somebody over tightened your bleeder screw. It is a common issue. Stick with the plastic screw, it is much easier and less expensive to change the screw, rather than changing out the combo hose with the t-fitting. If you overtighten the brass screw, it will break or strip out the t-fitting and then things get expensive. The plastic screws are about $4 each, buy two or three and keep the extras in the coin drawer in the dash to the side of the ac controls. Make sure that you bleed the system when you get the new screw. Good luck. Phil
Old 01-15-2012, 01:26 AM
Senior Member
Quote:
Top Hose Brass Bleed Screw Land Rover Defender & Discovery 2 TD5
Here is the link to the part, but I paid half this, so I'm sure you can find it cheaper.
http://item.mobileweb.ebay.com/viewi...d=270859894980
__________________
Fight On USC!
Old 01-15-2012, 07:18 AM
94svt50's Avatar
Senior Member
Thanks for the replys. I have had the screw out a few times while bleeding system from water pump change. The weird thing it's bubbling from the very center of the screw.
Old 01-15-2012, 06:34 PM
Senior Member
mine did the same thing with two different bleed screws. The center area seems to be the week spot on the design. Good luck. Phil
Old 01-15-2012, 07:00 PM
Rover_Hokie's Avatar
Senior Member
Is the plastic bleed screw replacement a dealer only part?
__________________
Tony
Black '01 D2 SE 135K AMSOIL Synthetics
HG Jul-11, Magnacor 8mm wires, NGK plugs, TW front driveshaft, QT diff guards, TF steering damper, BottorF'ed rear bumper w/swing-away modified, Yokohama Geolander AT-S LT245/75/16, SS ext brake lines
Waiting for time to install:
1) WABCO ABS repair kit
2) MD OME Springs still need to get some shocks
3) Used SD rack that came with 4 Hellas and a rear work light
GO HOKIES!!
Old 01-15-2012, 08:01 PM
94svt50's Avatar
Senior Member
It's a dealer part that you have to buy the housing to get or you can get the screw seperatly from a BMW dealer.
Old 01-15-2012, 08:12 PM
Senior Member
Quote:
You have to buy the entire T assembly in order to get the screw from why I gather when i had the same issue.
__________________
Fight On USC!
Tags
bleed, bleeder, bmw, discovery, hose, land, landrover, leaking, number, part, rover, screw, skrew, valve, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
