Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > Discovery II
Register Forgot Password?
Old 01-21-2012, 06:48 PM
nik nik is offline
Junior Member
Default Body control module trouble
Hello, I will start by saying that I am new to this Rover thing. I can say that for the short time that I actually got to drive the truck,I really liked it. Sort of a mix of a early 90s Land Cruiser and late 70s Scout 2, seemed like fun. I had gotten all of the basic new (to me) car bits and pieces, plugs, wires, oil change, air filter,battery, and had started putting together stuff to do the maintenance from the major service thread. I changed the battery, with no issue, fortunately missing the potential problems which I read about after the fact, involving the alarm and other electronics. It was all going so well.
Then the fun stopped, I noticed that the drivers door would not respond to either the center lock button or the key fob. All other doors were working fine. After getting back home, I tried to lock the door with the key. And yes it worked, but it also turned on the alarm. The horribly invasive, deeply rooted alarm, that will not turn off, or let the engine crank.
After a bit of homework, and some help from Atlantic British, I changed out the driver's door lock actuator, disconnecting the battery about 2 minutes into the project. The rest of the swap went smoothly, in a far more peaceful state of mind. I did notice that the new part had 7 pins in the elec. connector while the old one had 8. but all of the part numbers matched, so I went ahead.
No, it can't be that easy, the alarm still won't die, so a bit more homework, and a few things that seemed closer to witchcraft than auto mechanics (universal eka codes, disconnect and reconnect battery with key in position 2...) Still no luck.
I was about to leave town for a week over Christmas, so I admitted defeat and had it towed to the dealer, thinking it would be expensive, but it would be done by the time I returned. After many diagnostic hours they tell me that the bcu is bad and they need to order it. At the Cleveland airport, on the way home, I get a phone call saying that the part is back ordered, with no estimated delivery date.
Now, almost a month later, I am still waiting for a part with no estimated delivery date. So the question is this; Can a used bcu be reprogrammed to work with another ecu, or am I just stuck at the mercy of Rover and their shipping department?
Any help/moral support/verbal abuse would be great.
99 disco 2, v8, coil sprung, stock aside from an aftermarket radio, 150,000 miles
Old 01-21-2012, 08:00 PM
Senior Member
I believe that a used one will work. I think the system may recognize it and adapt without dealer intervention. Of course, you may want to consider purchase of a Hawkeye, which will communicate with it, for a price. Or get it going and have dealer program it. Like for no immobilization....
From RAVE workshop manual:
The IDM communicates with the BCU and the instrument pack via a serial interface. If the BCU or the IDM is replaced,
the communications link between the two units has to be re-established. This can be done either by switching on the
ignition and leaving it on for five minutes, or by using TestBook. The vehicle immobilisation will remain active until the
communications link between the BCU and IDM has been re-established.
__________________
Old 01-21-2012, 09:01 PM
nik nik is offline
Junior Member
Thanks Buzz, quite helpful.
In buying a used bcu, are there any compatibility issues between years or options.
Old 01-21-2012, 09:08 PM
Send a message via Skype™ to Disco Mike
If you send me your number and I'll walk you thru fixing this. Also You can buy a used guaranteed BCU, if it needed and have it shipped Monday.
__________________
Mike
Retired service manager. Member of the Solihull Society, NCLR club, SCLR and Santa Barbara 4 Wheelers.
99 D2, 3" lift, CDL with a Detroit and T.T. lockers, H.D. axles, 4:11 gears, Custom front and rear bumpers, sliders, Warn winch, and 5 HID's.
To Download the RAVE Manual, follow this link http://www.landroverresource.com/
Rover Radio issues or IPOD Adapters http://home.valornet.com/splacket/index.htm
Need Parts?
paulgrant@mac.com, or 203-770-1699
willtillery@roverguy.com, or 434-251-9331
Paul PTSchram 260-804-0458
PM Marty(Drillbit)[url]http://www.landroversonly.com/forums...o=newpm&u=5940
British Parts of Utah, http://www.bputah.com/
Lucky8, http://lucky8llc.com/
Old 01-22-2012, 07:14 AM
Senior Member
A used BCU will work with absolutely no issues. Security learn must be initiated on the Motronic to learn the code from the new BCU and your key bar codes must be entered into the replacement and you're good to go.
All years are cross-compatible and in addition to the above the "new" bcu will have to be programmed to your vehicle specific options.
__________________
'03 D2
Super Pro Bushes; Was Koni HT, now HT RAID; Detroit Rear & TT Front; CDL then Quife torque biasing center diff; Style A Wheels; Scorpion ATRs; Goodridge Stainless Lines; EBC YellowStuff on DBA 4000XS; Big Valve Heads; 202 Cam; Stroked to 4.8L; Tuned Motronic; Added ACE & SLS; Euro Headlamps W/ Leveling & Powerfold Mirrors. Forced induction coming next.
Old 01-22-2012, 01:02 PM
Senior Member
you could just take out the bad motor from the old one and install it in the new one.
of course you can turn the key in the door to get it to lock and unlock if you need to.
__________________
"If you think it's expensive to hire a professional to do the job, wait until you hire an amateur." Red Adair
Land Rover technician Got a problem just ask. If you are a fellow LR tech then I would like to hear from you.
Old 01-23-2012, 06:03 AM
nik nik is offline
Junior Member
Thanks to everyone for the input, now it is just a matter of weather the dealer will work with used parts.
As an aside, what options can be disabled on the alarm? If possible i would like to completely eliminate it , but I understand that is unrealistic due to the complexity of the system.
Thanks again: N
Old 01-23-2012, 06:48 AM
Senior Member
The options to disable the alarm, superlocking, immobilization, etc. are all program options for the BCU. Tell the dealer you will sign for no warranty on customer provided parts. See attached program options.
I'd get rid of them all, considering the misery they can inflict. I have insurance to cover loss, and I'm pretty sure there are a number of owners who would like someone to steal their Disco. Of course, I don't live on Ave Y in Brooklyn, where you have to take your engine block inside each night....
__________________
Old 01-23-2012, 07:32 AM
hilltoppersx's Avatar
Senior Member
edtatton
id be more worried about myrtle than Ave Y...
to the OP why are you having a dealer install a used part? why not do it yourself?
__________________
-Ed
99 DII, TF +2" HD & steering damper, TreadWright 265/75/16, ARB front, BritPart rear, Warn m8000 with synth, Columbia Overland gate panel & dual battery tray, Safari snorkel, RoverBones diff guards, RockWare sliders, DieHard Plat Deep Cycle, Chalkboard Headliner, CB, Wilderness Rack, 6 hella 700 ff's w 100w bulbs, 2 hella work lights
93 RRC TF track rod, tie rod & steering damper, TRW rims
Northeast Land Rover Club
www.nelrc.com
Old 01-23-2012, 07:37 AM
jafir's Avatar
Senior Member
I don't think you are going to be able to install a used BCU without a way to resync it with the ECM. A hawkeye will not do this. There are some aftermarket tools that will.
__________________
______________________
Jafir
2003 Discovery S, 132K
2004 Acura TL
1999 Discovery II, 110K (Project)
Tags
2006, 97, bcu, body, control, controlmodule, disco, discovery, installed, land, module, range, repair, rover, start, swap, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
