Brake drum assembly removal from t case
All-
Im installing the new used t case in my 01 discovery 2. I read about removing the brake drum assembly for more clearance. I got the drum off and the 4 bolts off. Do I need to remove the rear t case out put flange off to get the assembly off? If so does anyone know the socket size?
Thanks,
Kevin
Thanks,
Kevin
All-
Thanks,
Kevin
Thanks,
Kevin
IMPORTANT ensure the truck is on good 2 to 3 ton axle stands and safe from falling onto you and leave the wheels on and a trolley jack under the front and rear diffs as you will tugging around under the truck. Check the RAVE manual for the correct torque setting for retightening the shaft nut and preferably use a new nut and felt washer.
bcolins
03-08-2015 07:14 AM
bcolins
02-09-2014 08:35 PM
transpartstech_rover
03-02-2010 02:13 PM
JBEGIN
04-30-2009 01:19 AM
