BRAKE light keeps flashing
Old 12-16-2007, 05:16 PM
LRDISCO's Avatar
Default BRAKE light keeps flashing
I took out my 2002 disco and drove it through the yard and the BRAKE light that appears when you have the emergency brake on will come on momentarily and go off i drove over some roots and it would blink every once in awhile. What could be the problem??
Old 12-16-2007, 05:36 PM
Default RE: BRAKE light keeps flashing
Check your brake fluid level and add if it is low. If that doesn't fix it you will need to adjust the e-barke cable.
Old 12-16-2007, 06:15 PM
LRDISCO's Avatar
Where do i check my brake fluid level?
Old 12-16-2007, 06:24 PM
LRDISCO's Avatar
Ok nevermind i found the brake fluid. so how do i adjust the ebrake cable??
Old 12-16-2007, 07:26 PM
willstevens's Avatar
Do you have a rave cd? It has step by step instructions on everyting including this project. a bit lengthy to write out. Let me know if you need the info and I can e email it to you.
Old 12-16-2007, 08:13 PM
I get the impression you are not very mechanical so I would suggest you go see a mechanic.
Old 12-16-2007, 08:51 PM
LRDISCO's Avatar
Could this be anything serious? besides ebrake cable?
Old 12-17-2007, 09:24 AM
That's why you need to go see a mechanic and don't drive it till you can get it into a shop.
Old 12-17-2007, 11:53 AM
loic's Avatar
is the "arm" for the parking brake all the way down ? it could just be the switch..
woley
01-20-2010 12:53 PM
Gilbert
06-08-2009 11:33 AM
tomeytos
04-30-2008 10:38 PM
gsgtsg
01-23-2008 01:46 PM
Quick Reply: BRAKE light keeps flashing
