Brake warning light?
Checked the float and even pressed it up to the cap and the light is still on, checked the p brake switch, pressed it all the way in and still no change. I still need to check my pedal switch, but it must not be the switches because my taillights work perfectly. I'm wondering if it has anything to do with the trailer brake system that the previous owner had installed
Guys I'm still stumped on this one, i've tested my pedal, parking, and brake res cap switch, and they are all working, my res it topped off, but my brake light is still staying on. Could it be the brake module? One thing to mention, when I press the pedal, it makes a fairly strong clicking sound from the center console. Is this just the normal sound it makes when the tail brake lights come one? Thanks for any help, I should also mention that I have 3 amigos
