Burning Oil Odor
Burning Oil Odor
Just wondering if anyone else has dealt with a consistent burning oil smell with their DII and how they've gone about diagnosing it? I switched over to synthetic oil about a year ago (oil change place) and shortly afterward started smelling burning oil. I figured that perhaps some oil had spilled and was burning off but it continued on for the next six months or so. I know my vehicle is old, and maintenance is due. Probably should get it in somewhere to have it looked at as I don't feel comfortable doing motor work myself. I know that it's leaking somewhere as I have oil on the driveway underneath the engine. I suspect my valve cover gaskets are leaking as I can see oil around them but don't know if anything else is contributing to the burning smell. Once the weather warms up here (in the next few days) I'll climb under and clean her off with some brake cleaner and try to pinpoint. Just looking for ideas as it's getting pretty bad. I can smell it in the Rover when I run the fan, defrost, etc. It permeates the air as well around the hood area when I shut it off and get out. Anyone have a rough estimate as to how much a valve cover gasket change-out costs at an independent shop?
Many thanks,
Christina
Many thanks,
Christina
Once upon a time I had that burning smell all the time. Your suspicion might be correct from the gasket. It could be dripping towards the exhaust manifold which hardly noticable because it burns and dries it before you can visually see it. Unless the leaking is stopped, then determining the issue is much easier. Gerry
Many thanks,
Christina
Many thanks,
Christina
Thanks Gerry & CJ,
Yes Offroad, I have a slow drip that marks its territory at work and at home but not a noticeable reduction in oil in the system. I do notice it however on the driveway as it's emulsified with the snow and made a lovely color on the black top over the winter. I use 10W30.
'Engine breather'.. I will check this once I figure out where it's located haha. Exhaust pipe sounds logical too - I'll check that as well and clean up any messes in the next week and report back.
thanks again
thanks again
I have 128k on my 04 and i can see the oil seepage from the valve cover gaskets. Cold here in CT and I just don't have the time to pull 'Winston' apart right now. It will be part of other work i need to do like injector o-rings, since I have the perpetual 1171 &1174 codes and have done everything but the o-rings to kill them.
It's nice to know that it can go away haha. I'll have to poke around and clean it up down there, see if I can find the cause of the leak. Your suggestions have given me something to work with though, so thank you.
My colleague just showed me this clip. He said that he sometimes feels this way when working on code. I feel this way when trying to figure out Rover issues Trying something different every single time and getting the same result.
I'll never get it!!! NEVER!!!!
Mine is currently doing this as the valve cover gaskets are starting to give. It is dripping oil off the rear of the block, passenger side right onto the downpipe cat. I literally caught it in the act by popping my hood immediately after parking it after a longer drive and I saw the smoke from the oil burning off the cat. I'm looking forward to fixing that soon.
