Codes 1170 and 1173 - Land Rover Forums - Land Rover Enthusiast Forum
Old 06-11-2012, 11:53 AM
Junior Member
Default Codes 1170 and 1173
Hey Everybody. I am getting these 2 codes but don't know which side of the LR it is talking about.
P1173 Land Rover Lambda sensor aging tv bank 2Drive cycle C:Signal out of range - .............................P1170 Land Rover Lambda sensor aging tv bank 1Drive cycle C:Signal out of range - above maximum / below minimum
I appreciate the help.
Thanks
Old 06-11-2012, 12:19 PM
One sheet I found said for the "LH" bank.
How many miles on your engine, have you ever changed your 02's?
Old 06-11-2012, 12:24 PM
Junior Member
Thanks for the help.
Is that the left side when sitting in the vehicle or standing in front and looking at it? I haven't replaced any of them and know it is time. 90,000 miles.
Is the one code for the upstream and the other for the downstream on the left hand side? That is my guess
Old 06-11-2012, 01:11 PM
drowssap's Avatar
Senior Member
right hand and left hand is alway from sitting in the vehicle
Old 06-11-2012, 01:16 PM
At your mileage, I would replace both front 02's and clear the codes, see what happens.
Thread Thread Starter Forum Replies Last Post
Codes 1170 and 1173 after cat delete MC04DII Discovery II 27 11-13-2012 09:00 PM
1173 Code Check engine Light. Please Help bosshogt Discovery II 10 09-25-2011 12:07 AM
service engine light just came on 62,000 ODB 2 code 1173 operez818 General Tech Help 3 02-14-2009 10:34 AM
HSE 2004 62,000 OBD 2 code 1173 Please HELPPPPP operez818 Range Rover 2 02-12-2009 08:01 PM
code 1170 need help pls jasondm Range Rover 0 02-05-2009 03:45 PM
Tags
1170, 90000, code, cost, discovery, downstream, lambda, land, mileages, p1170, p1173, range, rover, sensor, updates, upstream
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
