Coil Pack replacement?
Old 03-07-2010, 02:16 PM
tmckenz's Avatar
6th Gear
Default Coil Pack replacement?
Hi gang, just want to double check myself here. My '03 disco is running really rough. Having already replaced the plugs and wires with no improvement, I borrowed a code reader. Codes say that 2, 3, 8, and 5 are misfiring. I'm thinking bad coil. Any other possibilities?
Old 03-07-2010, 02:34 PM
Yes, your passenger side coil failed, replace them both. Whos plugs and wires did you use?
Old 03-07-2010, 02:51 PM
tmckenz's Avatar
6th Gear
Unhappy
Thanks for the confirmation. Unfortunately, I didn't do any research before I bought plugs and wires. I bought whatever they had at the local parts store. I guess I'll be doing that again soon.
Old 04-23-2010, 09:28 PM
mdemet's Avatar
3rd Gear
Here are some photos from a recent coil pack replacement my son and his buddy (high school seniors) did for me. It took about 2 hours total. Get a new coil pack, intake manifold gasket and I recommend you do the head cover gaskets at the same time.
https://landroverforums.com/forum/members/mdemet-9369-albums-coil-pack-replacement-284/
Old 04-24-2010, 04:40 PM
Arm and hammer's Avatar
How come I can't see any pictures?
Old 04-24-2010, 04:44 PM
I see his pictures.
Old 04-24-2010, 05:07 PM
Arm and hammer, you do not have permission to access this page. This could be due to one of several reasons:
  1. Your user account may not have sufficient privileges to access this page. Are you trying to edit someone else's post, access administrative features or some other privileged system?
  2. If you are trying to post, the administrator may have disabled your account, or it may be awaiting activation.
This is all I see.
Old 04-25-2010, 07:52 AM
That is right, didn't you read the information when you signed up, you are restricted as to what you can do till you have ten posts, if I remember right, then you will have full access to the entire site.
Old 10-30-2010, 05:07 PM
uniden290's Avatar
7th Gear
this is my first one
Old 10-30-2010, 05:11 PM
uniden290's Avatar
7th Gear
Default upper intake removal?
I'm trying to replace the coil pack in my 2K DII. Does anyone know a way to do it without having to remove the upper intake manifold? As far as i can tell it's pretty much locked in there and no way to get it out without doing that. Also, if I do have to remove the upper intake, what's all intailed to that. Is it just a matter of removing the bolts, lifting it, replace the gasket and tighten the bolts. Do they have to be torqued?
Quick Reply: Coil Pack replacement?
