Coil under the coil packs?
Old 10-28-2014, 08:33 PM
trialrun's Avatar
And I leave you with my question of the night these gaskets came with the kit, I can't figure out where they go, anybody???
  #62
Old 10-28-2014, 08:49 PM
Kenso's Avatar
Just did the HG's on my '03 and had the same stuff left over, the consensus was that it's for the older engines such as the D1 since they all use the same HG kit apparently.
https://landroverforums.com/forum/di...-hg-kit-69921/
  #63
Old 10-28-2014, 10:34 PM
trialrun's Avatar
https://landroverforums.com/forum/di...-hg-kit-69921/[/QUOTE]
Good deal, little worried for a quick minute
  #64
Old 10-29-2014, 04:38 AM
drowssap's Avatar
universal kit always has a little extra
  #65
Old 10-29-2014, 08:56 AM
trialrun's Avatar
weird that they'd include all that and not the coolant elbow tapered o ring, got that on order to arrive today and the two oil pan gromments. Hopefully this thing will be back up and running for the snow coming this Saturday
  #66
Old 10-29-2014, 10:00 AM
drowssap's Avatar
you seem to be making pretty good progress on it though. screw the snow.
Funny, like you say they give you extra and leave out things like the upper manifold gasket.
to late, but that was not a bottoming tap you used to chase the threads.
keep plugging away
  #67
Old 10-29-2014, 04:15 PM
RoverMasterTech's Avatar
If that truck is from NJ. I remember breaking your fuel line when I put a new motor in your truck after it blew up at 6,900 miles on my way to burger king.
  #68
Old 10-30-2014, 07:02 AM
drowssap's Avatar
that would be strange if it were the same truck
  #69
Old 10-31-2014, 09:14 AM
trialrun's Avatar
Interesting, I actually bought it from a couple out of Woodbridge, CT which isnt far from NJ. I'll post the numbers on the block face if you could let me know if it matches up to the engine you installed, would be great to know the history on this rig.
Plus, its an 03 that falls in the VIN range with block issues, so a piece of mind knowing that was replaced
  #70
Old 10-31-2014, 10:06 AM
Call land rover Monmouth an see if they have a history for it. They just need a Vin.
Quick Reply: Coil under the coil packs?
