Cold as hell - wont start 95 D1
Old 12-07-2009, 08:29 PM
mattrickman's Avatar
Default Cold as hell - wont start 95 D1
95 D1
Wont start today, its 7 degrees right now. Normally starts fine....
Any ideas?
Old 12-08-2009, 03:18 AM
LRScott's Avatar
What are the symptoms? We need more details to answer your question. Such as; is it getting spark and fuel, etc. Mine started in 9 degree weather yesterday without a problem.
Old 12-08-2009, 07:13 AM
antichrist's Avatar
Or even more basic, is it cranking at a good speed?
Old 12-09-2009, 10:17 PM
OK... fair enough. I just thought there might be something weather related that I was missing...
It is cranking fine. I even hooked it up to my 2500 Duramax to jump it, just in case it was a battery issue (I have an Optima Yellow Top so I didn't figure it was a battery issue).
I was too lazy (and too damn cold) to fool with a fuel pressure gauge, so I depressed the fuel valve and it squirted out a little bit, but not as much as I would figure with 30psi pressure.
If it is a fuel problem, is there anything that would cause low fuel pressure at cold temps?
Old 12-10-2009, 10:08 AM
98roverguy's Avatar
Hmm. I got mine started at -10 the other day. It moaned a little but it started. Have you gotten it started since?
Old 12-10-2009, 10:14 AM
Mine is start OK at -35, the last few days.
When was your engine last tuned, including a new Rover cap and rotor, plugs and wires? What octane gas are you running and when was the fuel filter last changed?
Might want to prime the injectors by first turning the key to the second position for 5 seconds, do this 3 times then see how it starts.
Old 12-10-2009, 01:04 PM
antichrist's Avatar
Ice in the fuel filter or pickup would certainly reduce the fuel pressure.
Old 12-13-2009, 07:13 PM
Default warmed up - problem still here
well, the weather has warmed up a bit, and it will crank but not start. Now that I have two rovers that won't run, I am going to just take them somewhere this week and have them looked at.
I like to fix my own trucks, but now is the absolute worst time....
Does anyone have a mechanic they can recommend in Northern Colorado?
matt
Scott Legan
03-02-2020 06:35 AM
disconic
06-04-2016 02:57 AM
snads
12-06-2014 02:42 PM
logicmike44
02-10-2012 08:24 PM
gustav23
12-15-2011 01:12 PM
Quick Reply: Cold as hell - wont start 95 D1
