Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > Discovery II
Register Forgot Password?
Old 01-20-2012, 09:57 AM
Member
Default Cold weather. Wont Start.
Driving yesterday and cut off at stop light, started back up, but not immediately. Started fine the rest of the day.
This morning 2 degree temp, tries to start and will not turn over, just revs, but wont start. The only code i get is p1884.
99 Discovery II
__________________
99 Discovery II
Old 01-20-2012, 10:23 AM
Send a message via Skype™ to Disco Mike
The 1884 is not the problem, that is a tag along code only and is not the problem. It is not the cold weather cause Rovers like cold weather.
How many miles on the truck, when was it last tuned along with 8 mm plug wires and what octane gas are you running?
__________________
Mike
Retired service manager. Member of the Solihull Society, NCLR club, SCLR and Santa Barbara 4 Wheelers.
99 D2, 3" lift, CDL with a Detroit and T.T. lockers, H.D. axles, 4:11 gears, Custom front and rear bumpers, sliders, Warn winch, and 5 HID's.
To Download the RAVE Manual, follow this link http://www.landroverresource.com/
Rover Radio issues or IPOD Adapters http://home.valornet.com/splacket/index.htm
Need Parts?
paulgrant@mac.com, or 203-770-1699
willtillery@roverguy.com, or 434-251-9331
Paul PTSchram 260-804-0458
PM Marty(Drillbit)[url]http://www.landroversonly.com/forums...o=newpm&u=5940
British Parts of Utah, http://www.bputah.com/
Lucky8, http://lucky8llc.com/
Old 01-20-2012, 10:27 AM
Member
177,740 miles, plugs and Magenecor wires march 2011.....87octane.
__________________
99 Discovery II
Old 01-20-2012, 10:36 AM
Snafu / Disco Fries's Avatar
Senior Member
Quote:
These require premium so that is a good place to start. Might want to throw some really good fuel injector cleaner and do a seafoam type cleaning too.
__________________
Garage:
00 Disco, Alveston Red
05 Audi S4 6MT, Nogaro Blue
12 Acura MDX Tech Grigio
Old 01-20-2012, 10:41 AM
Member
Thanks,
should i go buy a few gallons of premium and add it to get it to start?
Will the seafoam work without being able to start ?
__________________
99 Discovery II
Old 01-20-2012, 10:47 AM
Senior Member
Thanks,
No, I think you would fry your starter before getting any premium in there anyway. The seafoam needs to be done with the motor running, so that won't work. If you are going to throw something in, you might want to consider some of the stuff that gets the water out of the tank (always a possibility especially with cheaper gas). Might also want to consider some Lucas additive/cleaner or another one. I don't think this is the only issue honestly, but sure could be part of it.
Any other codes? Did CEL light come on?
__________________
Garage:
Old 01-20-2012, 01:59 PM
Member
no codes other than the p1884, the CEL has been on before for misfires. Weather will be warmer tomorrow, hopefully it will start...
Could it be water frozen in fuel line from 87 gas ?
__________________
99 Discovery II
Old 01-20-2012, 04:01 PM
Senior Member
Hard to say but honestly I would not think so. If you don't have codes though, I think if you get a few things to put in the tank it would help. Maybe just clogged up or dirty injectors + lower octane fuel and the timing set off by the computer to compensate for the lower octane.
__________________
Garage:
Old 01-20-2012, 10:12 PM
Philip Lawrence
Send a message via Skype™ to Spike555
Water remover is alcohol, which water sticks to and when used in the gas tank the water sticks to it and then it (the water/gas mix) is burned in the engine, thats how it removes the water.
Your problem is the 87 octane, you need to add as much premium fuel as you can and then try to start the engine, you will then have mid-grade in the gas tank.
As you try and start the engine it will remove the cheap gas from the fuel line and the mix will start to get to the engine.
Remember you get what you pay for when you buy gas, cheap gas is just that, CRAP!
Dont worry about any water in the gas, all gas has ethanol (grain alcohol) in it so the odds of you having any water in the tank is small.
You may have bought a tank of bad gas, it is always best to stick to a single gas station and of a name brand, like Shell or BP for example, but try and use a high volume gas station, meaning one that is always busy as they will have the freshest gas.
__________________
www.marshill.org
Walk by faith not sight.
The "Storm Trooper", 1997 Discovery with 212,000 miles.
www.20liters.org
Old 01-20-2012, 10:27 PM
Member
Thanks, I'll charge my battery (mostly dead from trying to start all day), get some premium, and try again in the morning.
__________________
99 Discovery II
Tags
cold, crank, good, land, rover, sensorno, start, weather
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
