Condenser Fan
Condenser Fan
Hey all, I believe my condenser fan is bad, is that normal? I looked in the Rave and its the fan just beneath the front grille. I have read through a couple of threads but nothing describes what I am hearing. It sounds awful. Any ideas on what could be wrong? It just started within the last couple of weeks as the weather warmed up. Does it need to have some kind of maintenance done on it?
Appreciate any advice
aux fan
what kind of noise?...maybe a blade is chipped and its out of balance..you can get a new fan from a wreaker...just replace it...and if you are not in FL or AZ i wouldnt let it make you loose sleep..disconnect it and dont get stuck in traffic fo hours you'll be fine. mine had been out for a summer and i ive in florida and mine never overheated...
Mike, going to be hard not to use it as its pretty warm here now and its my daily driver...any other suggestions until i get it fixed...i will try to find the parts ASAP
Your condenser fan does nothing more than move air for the a/c UNLESS the truck starts to overheat, then it will come on even if the a/c is off.
Yes they are $300 brand new, thats why you either buy a used one or replace the motor.
If you take the fan out you can take the blades off it and get a new motor or maybe even rebuild that one.
And...its dead
