Brakes, Three Amigos, etc.
I have a 2001 Discovery 2 with 120,000 miles on it. My brakes have been going bad over the last month or so and I know at least one, if not two of the calipers is shot. I was planning on ordering pads, rotors, and calipers all around. The three amigos just came on on my truck yesterday. Can this come on when pads wear to far down? Or is there another problem lurking now?
I'm going to order the brake kits today and was planning on going with the Proline front Pad & Rotor Kit, the Proline Rear Pad & Rotor Kit, and Proline Calipers all around - as the original ones are still on the truck and if I'm doing two I might as well do them all. Is Proline a good choice for all of this or does anyone recommend any other option in that price range?
I just want to make sure that these parts are good quality and that the three amigos is just due to worn brakes and will be resolved once I replace all those parts.
Lastly, any out-of-the-ordinary tools I need? I've done brakes before, just thought I'd check. I heard to bleed to Disco 2's you need a programmer to work the brake valves. I also heard engaging the Hill Descent and re-bleeding a few times will work instead? Correct or no?
Thank You
Thank You
Thank You
Thank You
I would swap pads and rotors and try and refurb the calipers.
yes, you can 'bleed' the brakes the dirty way you describe. I've never done it, although plenty of people have.
I did go with the akebono euros all around and ended up going with DBA Golds rotors all around after reading up on them on this forum. I already bought the calipers from RN new for $80, otherwise I probably would have when with those refurbs if I knew before I had already ordered. I'm only doing the front two calipers (the troubled ones) for now to counter the more expensive pads and rotors I went with. When I do the rear calipers in the future I'll definitely look into those refurbs more; thank you for that!
$160 +ship for both new front calipers from RN
$110 for all the Akebono Euros (EUR676 and EUR493) on Amazon
$140 +ship for the front DBA 092 Gold Rotors on EE
$180 with coupon for the rear DBA 093x Gold Rotors on HawkPadsDirect (sold out on EE)
....For anyone who wanted to know
From what I hear the pads and rotors will last a very long time with great results, so I didn't mind spending a little more on them.
you can bleed them the old fashion "pump up/ hold down" it works fine it you have a second person.
All I can say it start bleeding from the further point to the closest. in the US it would be RR, LR, RF, LF.
When you have money you should replace your brake hoses, they are 14 years now and they do get spongy.
