Cracked block
While driving car last winter the heat suddenly stopped working and a few minutes later engine overheated. Antifreeze pushing out of overflow tank and some out tail pipe. Heads removed both checked out at machine shop, new head gasgets installed but still have same problem. Check Engine light on indication of a missfire no. 5 cylinder. Any ideas?
cracked block
When engine was apart only a visual inspection was done, by a mechanic, who did not see any problems. I'm going to have the car towed home from the shop and will start a new tear down shortly. What should I look for? I had planned on buying a used engine tearing it down and putting new gasgets on it. What is your opinion? Thanks for your assistance.
