Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > Discovery II
Register Forgot Password?
Old 01-18-2012, 05:43 PM
Junior Member
Default Creak/Squeak when cold - suspension
Hey all,
I've got a 2000 Disco II with air suspension (replaced last year). When the temperature drops below about 40-45 degrees F, like in the morning, I get a pretty pronounced squeak/creak sound out of the rear suspension (possibly front too on occasion) when I drop off the curb or go over a speed bump. I'm pretty darned handy and have done a good amount of my own work on my Rover so I'm game to tackle this but I'm really not sure how to run it down to pinpoint what it might be. I'm hoping that one of you might recognize this as a "typical" Disco problem and lead me to it.
Thanks a bundle in advance!
Bob
__________________
2000 Disco II -- 125k+ miles
Makin' me better at auto repairs!
Old 01-18-2012, 07:24 PM
94svt50's Avatar
Senior Member
Im watching this thread, mine does the same thing since cold weather but, it seems to go away after driving for a while.
__________________
'03 HSE7 112k driveshaft/headgasket/water pump/oil pump/all fluids akebone pads and new rotors and I have almost had it a year
'02 pathfinder 160k
'89 yota 4x4 251k
Old 01-18-2012, 09:57 PM
bosshogt's Avatar
Senior Member
I had the same thing. I thought I had a bad wheel bearing or somthing last winter. I sprayed a bunch of Seafoam Deep Creep up around the front springs. That quieted it down. I may do the same for the rear air spings. I think road spray debris gets packed under the top seat/perch in on the rear springs and makes noises. It seems more pronounced when the temp goes below 20.
__________________
2003 Discovery HSE Magnecore, DBA Slotted Rotors, LR Ladder, G4 Lamp Guards, Headlight Guards, RN Hood Blackout, MagnaFlow CatBack, ScanGuageII, Optima Red Top, LR 16" Typhoon Black Rims, Goodyear DuraTracs, OME 2" Lift, Frt Botorff Bumper, Skid plate, Rear Bumper by Dave, HLC tire carrier.
Old 01-19-2012, 08:41 AM
drowssap's Avatar
Senior Member
while the deep creep my have worked on your coil spring you dont want to be spraying it on your air bags.
Oil will wrought and distroy rubber, that is why you grease rubber bushing and do not oil them.
If you have ever grabbed a radiator or power steering hose that has had oil leaking on it you know what i mean. you get that black slime all over you hands, thats wroughted rubber.
__________________
00 Disco 4.0 80k miles SLS, ACE, 7 passenger 255x65x18: Repairs since 02/11 new intake, valve cover, head, timing cover, waterpump & oil sump gaskets, new timing chain & gears, water pump, t-stat, hoses, belt, new front drive shaft, Akebono pads, D&S rotors, SS brake lines, clutch fan, HMS completed.
90 RRC County
67 mustang GTA
73 Jeepster Commandos
69 Honda SOHC
71 HD FX
72 BSA Lightning
73 Honda SOHC
78 Honda SS
87 HD FLTP
2004 HD SE 103
He who dies with the most toys, WINS
Old 01-19-2012, 09:15 AM
Big Jim Swade's Avatar
Member
Mine does the same thing, but it seems like most of the noise comes from the front suspension.
__________________
Big Jim Swade
2001 Discovery SE7 w/SLS, 62k miles
18" Comet Wheels w/Nitto Terra Grapplers
255/60-18's
2000 Nissan Frontier Crew Cab 75k miles
2008 MINI Cooper Clubman S 20k miles
1977 Datsun 280Z 225k miles
Old 01-19-2012, 11:53 AM
FightOnUSC79's Avatar
Senior Member
WEST.WEST.YALL John_R_Scott
Same here aon the few ultra cold mornings AZ has, but quickly dissipates as the morning drive goes on.
__________________
2004 Disco II SE 110K Miles on truck/48 on engine:
Rebuilt front drive shaft / mikes 60k service / new shoes / HG / 8mm STI wires / Akebono pads front and rear / New Rotors all around / OME Steering Stabilizer / Ultra Gauge
In the future: HLC Front and rear bumpers - OME Suspension - Safari Rack with Lights - Let the saving begin
Arizona Land Rover Owners Member AZLRO.org
Fight On USC!
Old 01-19-2012, 12:14 PM
Junior Member
Default How to make it better
So, in reading the RAVE manual, it seems that there is basically the Dampers and their bushing, a few other bushings in the rear, and then the coils/air-bags. If this is happening to folks in front and rear, then I'm inclined to believe the common thread is dampers, but I'm **FAR** from an expert.
I'd love to know what to check and/or replace and/or GREASE. I'll be giving it a good visual inspect this weekend if the weather permits but I don't have much belief that visual is going to help. Any pros wanna weigh in on our creakin-chilly-rovers?
Thanks!
bob
__________________
Old 01-19-2012, 05:44 PM
Junior Member
It's a sound like Plastic rubbing on rough metal connected to chassis. A real groaning noise when the thing is cold. But as you all describe it goes quiet after a while.
Old 01-19-2012, 11:36 PM
lordmorpheus's Avatar
Senior Member
I have had the same squeak/groan noise in the winter months for the past three years. It sounds like it is coming from the rear suspension (no SLS on mine), and really only happens when it is below freezing. I have not investigated it, because being out in the sub freezing temperatures causes me to make groaning noises also...
__________________
2000 Disco II 113,000 miles
Maintenance: 60K service with BG fluids, front drive shaft rebuild, Denso iridium plugs, front O2 sensors, Akebono ceramics front and rear with new rotors, belt tensioner and idlers, brake fluid and coolant flushed every two years- regardless of miles
Upgrades: OEM brushguard and driving lights, 04 CDL, extended rear axle breather, DI wiper arms, heated seat kit, grey painted chalkboard headliner
Tags
bump, cold, land, make, morning, oil, rover, shocks, speed, squeak, squeaking, squeaks, sti, suspension, weather
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
