Cruise control stop working - Land Rover Forums - Land Rover Enthusiast Forum
Old 03-02-2011, 08:31 AM
mwood2121's Avatar
Member
Default Cruise control stop working
The cruise control quit working this weekend on my 02 disco SEII. I checked the fuse that runs it and the electronic mirrors and it was fine as the mirrors still worked. Any ideas? Not mechanically sound here.
On another note, wife said heat or air wouldnt come on on the way to the gym this morning but then came on on her way to work. Any relation to the cruise not working? Electrical problems?
Thanks for any help!
Old 03-02-2011, 09:27 AM
longjon76's Avatar
Member
I am, by no means, an expert on LRs but the vacuum lines tend to be what causes the cruise control to crap the bed. Typically, they split at the ends so you can actually just cut the split portion off and reuse the same line or you could buy new. Do a search for that and you'll probably be good to go.
Old 03-02-2011, 09:31 AM
Forrest's Avatar
Junior Member
Hello,
First check the vacuum hoses; but most likely it is the switch on the brake pedal. If it is 'loose' it will not make contact with the bracket and will keep the cruise from working.
Good luck,
Old 03-02-2011, 11:01 AM
EstorilM's Avatar
Senior Member
Just check the vac line going to the actuator, mine cracked (and continues to) where it goes over the barb. I just keep cutting off the cracked piece and sticking it back on. Going to redo the vac lines this summer, that'll be fun.
Old 03-03-2011, 06:55 AM
mln01's Avatar
Senior Member
When diagnosing a problem that can have multiple causes always start looking at the least expensive, easiest fix first, and then work your way up the food chain. That definitely applies here since most DII cruise control problems are due to a cracked vacuum hose. It is a simple, $2 fix. And if it doesn't solve the problem you've eliminated it as a cause for the next several years for next to nothing.
Old 03-03-2011, 12:23 PM
LRDII2000's Avatar
Member
Ok I searched the RAVE and can't find where the vac hose is. Anyone able to point it out?
Old 03-03-2011, 01:45 PM
mwood2121's Avatar
Member
LRD, check out page 18-2-84 in the workshop manual and you will find info. there about the line and the actuator connection or location. Havent had a chance to look at this fix yet but I do appreciate the input!! Ill let you know what turns up but as my luck has it, wouldnt be suprised if its the cheap fix! Thanks all!
Old 03-03-2011, 06:14 PM
LRDII2000's Avatar
Member
Thanks mwood! Hopefully I'll have cruise tomorrow.
Old 03-07-2011, 10:53 AM
mwood2121's Avatar
Member
Alright, to finalize this thread and kill it, I noticed the horn not working the other day as my wife has not. Long story short, blown fuse under the hood for the horn and what do you know, fixed the cruise control as well. Boggles the mind...
Thread Thread Starter Forum Replies Last Post
1999 Discovery I SD Cuts out in Traffic/at Stop Light/at rolling stop/when A/C is on colemtd Discovery I 16 11-19-2014 01:28 AM
transmission hesitation from stop and rolling stop CapeRover LR3 18 05-03-2013 05:35 PM
Cruise Control not working discov 2001 Carlton1 General Tech Help 7 07-25-2012 08:51 AM
Brakes sometimes stop working, ABS not working, but ABS dashboard light is off. johnkbl Discovery II 2 01-13-2009 09:54 PM
Cruise Control not Working bklahl Discovery II 4 08-29-2007 12:20 PM
Tags
2000, 2002, control, cruise, cruisecontrol, discover, discovery, ii, land, landrover, problem, range, rover, work, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
