Dash Brake Light Stays on - just cold?
the light serves 2 functions...........1. to let you know when there is insufficient fluid in the reservoir, and 2. to let you know that the brake lever has been applied. and therefore 2 "switches" one at the reservoir and the other I believe is attached to the handle hidden by the center console. so...yes by all means check your brk fluid, make sure that the handle is all the way off, and then maybe the cable hasn't come all the way back to the off position...and that means getting under the truck and checking out the cable situation
dankdistrict
01-28-2010 11:10 PM
