Disco 2 now not cranking after coil pack replacement
2001 Disco 2, 145k miles
year ago had the plugs and wires replaced, just recently had the coil pack replaced with a salvaged part. Run great until today. Now the engine turns over at start but no start. I cleaned the battery connection, battery is good, alt is good, starter seems good, tried to jump it with another car but still it will not crank.
Is the coil pack to blame? and what needs to be done to fix the issue?
TIA
sparky
TIA
sparky
I replaced the coil pack because it was sputtering when I had the air on and would be climbing a hill. The service engine light came on and the codes read misfire in 1 and 6. I just had new magnacor wires and bosch plugs put on one year ago. The shade tree mechanic said it was probably the coil pack. Now I am sitting here with the engine turning over put it will not crank.
Another friend said to spray starter fluid on the carbirator then see if it cranks. If yes, then it is a fuel issue, if it still doesn't crank then it is a firing issue.
What do you recommend?
TIA
sparky
TIA
sparky
