Disco II fan exploded -- need some help
Good luck with the repair and your are welcome for the help. I made some edits to my parts list above I don't know if you saw them or not.
Download the RAVE repair guide if you have not already. It has all the step-by-step instructions you will ever need to repair your Rover.
Please do yourself a favor and buy the Genuine 180 T-Stat. It's only $30 more and it's worth it.
Also check your motor mounts. your's may be broken!
This is the second mention of motor mounts. These are what the engine bolts to on the chassis right? How does one check if they are broken? Visual inspection? If they are broken, I'm guessing you have to lift the engine to replace them?
thanks for the warning, but I was absolutely going to stay away from the engine when trying to crank it.
Put a jack under the oil pan with blocks of wood on it and slowly and gently lift the engine a little to see if the mounts separate. you will have to lift the engine enough to take the weight completely off of the mounts before you will be able to see if they are broken but, not so much that you break them if they are not already broken.
Yes you have to lift the engine a little to put them in, first see if they are broken and if so we'll help you put the new ones in.
Watch your fingers in there around all of that.
Why in the world would you risk doing this all over aging to save a few bucks on a used fan? You really have no idea what condition the used fan he has is in. I've had plenty of people on criagslist tell me there Disco was in excellent condition, but when I show up it's clear that our definition of excellent is way different.
I don't mind buying some parts used. Old plastic parts that spin at 3k RPM and can stop you dead on the road if they fail, are not something your want to buy used. Spend a little now or a lot later.
I got a chance to assess the damage a little more. Some observations:
1- Radiator seems unharmed and is Nissen brand and looks relatively new. I'm going to try to stick to it and not replace.
2- There is no play in the water pump shaft. If I take off the belt and it spins freely, does it really need to be replaced?
3- The fan took out my top part of the airbox, maf and also the connector tube from the maf to the intake, so a few more parts I need.
4- (this one bugs me the most). The maf connector is toast and one of the wires is severed. If I can get my hands on a used maf connector, could I simply splice and solder (i'm good at that)? If I have to change the whole wire, it seems like it goes into the bowels of the engine and that it will be a big job to disassemble.
