Disco transmissions - Land Rover Forums - Land Rover Enthusiast Forum
Old 07-13-2009, 06:33 PM
detailjohn's Avatar
Junior Member
Default Disco transmissions
I was just wondering, I have a 1995 Discovery, what other years transmissions will fit in this car? Can you install a newer model, or are they exactly the same?
Thanks,
John
Old 07-13-2009, 08:43 PM
d2luvr's Avatar
Senior Member
Disco I uses a ZF 4HP22 no computer, the DII uses a ZF 4HP24 computer controlled tranny. You might try looking at RR classics which are basically the same chassis.
Old 07-13-2009, 10:01 PM
John, what is wrong with yours, how many miles on it?
Old 07-13-2009, 10:52 PM
Senior Member
If it is from another DI then no problem.
Old 07-13-2009, 11:07 PM
detailjohn's Avatar
Junior Member
Quote:
Well, I just bought the car, and did a trans. service, and found quite a bit of shavings in the trans. pan. Fluid was also pretty burnt. It seems fine now, but just want to be prepared if it starts slipping. The truck has 148K miles on it. Not sure of any service history.
John
Old 07-14-2009, 09:48 AM
Do another drain and fill to get rid of some more of that old fluid, don't change the filter again, then see how it runs.
As for the tranny, 94 and 95's are the same, 96 thru 99'a are different.
Old 07-14-2009, 01:10 PM
detailjohn's Avatar
Junior Member
Sounds good thanks for the advice Disco Mike. I will do this.
John
Thread Thread Starter Forum Replies Last Post
Are the D1 and D2 transmissions interchangeable?? Second2None Discovery II 7 01-07-2016 03:06 PM
99 disco II compatible transmissions ??? parkerlander Discovery II 4 03-11-2014 01:58 PM
transmissions fluid JumPeR04 Discovery II 10 11-06-2009 12:36 AM
RR Manual Transmissions EFS Private For Sale/Trade Classifieds 0 09-27-2008 12:01 PM
Phoenix Remanufactured Transmissions? Bene General Tech Help 1 10-28-2005 12:09 PM
Tags
2000, 4hp24, computer, disco, zf
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
