Disco transmissions
Old 07-13-2009, 05:33 PM
detailjohn's Avatar
Default Disco transmissions
I was just wondering, I have a 1995 Discovery, what other years transmissions will fit in this car? Can you install a newer model, or are they exactly the same?
Thanks,
John
Old 07-13-2009, 07:43 PM
d2luvr's Avatar
Disco I uses a ZF 4HP22 no computer, the DII uses a ZF 4HP24 computer controlled tranny. You might try looking at RR classics which are basically the same chassis.
Old 07-13-2009, 09:01 PM
John, what is wrong with yours, how many miles on it?
Old 07-13-2009, 09:52 PM
If it is from another DI then no problem.
Old 07-13-2009, 10:07 PM
detailjohn's Avatar
Well, I just bought the car, and did a trans. service, and found quite a bit of shavings in the trans. pan. Fluid was also pretty burnt. It seems fine now, but just want to be prepared if it starts slipping. The truck has 148K miles on it. Not sure of any service history.
John
Old 07-14-2009, 08:48 AM
Do another drain and fill to get rid of some more of that old fluid, don't change the filter again, then see how it runs.
As for the tranny, 94 and 95's are the same, 96 thru 99'a are different.
Old 07-14-2009, 12:10 PM
detailjohn's Avatar
Sounds good thanks for the advice Disco Mike. I will do this.
John
Second2None
01-07-2016 02:06 PM
parkerlander
03-11-2014 12:58 PM
JumPeR04
11-05-2009 11:36 PM
EFS
09-27-2008 11:01 AM
Bene
10-28-2005 11:09 AM
Quick Reply: Disco transmissions
