Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > Discovery II
Register Forgot Password?
Search
Old 06-28-2012, 09:08 PM
Member
Post Discovery II Electrical Library & Diagrams
Anyone know where I can get the Discovery II Electrical Library and Electrical Diagrams? I'm trying to repair a hacked up harness on a 2004 d2.
Old 06-28-2012, 09:15 PM
jafir's Avatar
Senior Member
land rover service factory manual RAVE download land rover resource, service manual, workshop factory manual, download, rave, vehicles including discovery, series, defender, range rover, freelander, LR3, Handbooks, Catalog, Catalogue, Land Rover Inte
Get the one with the big file warning.
__________________
___
Jafir
Current rides:
2003 Discovery S, 136K, 3ish inch TF Prosport lift, ARB bull bar, Warn-ing M8000, 255/85R16 BFG KM2, Greg Davis Rear bumper (not installed).
1987 D90 ex-mod 2.5NA LT77 1.66 LT230 stock for now. 7.50R16C Michelin XZL. D1 axles, Qt diff guard, and TF +2 Prosport shocks all waiting to be installed.
2004 Acura TL, daily driver... I'd like to trade it and the D2 for an LR3 daily driver.
Previous Rovers:
1996 D1 SE7
1999 D2 SE7
Old 06-28-2012, 11:13 PM
Senior Member
the link in my sig takes you to all the downloads as well. i just had to go digging through the electrical diagrams for a window issue.
__________________
2003 Discovery
120k
Land Rover Manuals http://macassemble.com/lrm/
Old 06-29-2012, 05:17 AM
and here are some more links, including the ECU manuals which are not in the RAVE. When looking at circuits, those tiny numbers are the connector numbers, switch over to electrical library and they have photos of the location and pin outs for whole connector, on Discos that have never seen daylight, much less the trail or an oil leak. You'll also want to look at the start of the manual for the color code (like K = pinK, U = blUe, etc.)
__________________
Free download of RAVE and Rover shop & owner manuals (LR3 and older) in pdf: http://landroverforums.com/forum/gen...ing-lr3-57978/
Workshop/electrical/owners/overhaul/ECU for Discovery, Range Rover, Freelander, LR3, and older models
Cooling System Problems: http://landroverforums.com/forum/gen...verview-51034/
Old 06-30-2012, 01:02 PM
Member
The rave and other electrical electrical diagrams I keep finding are labeled up to 2003MY. I'm working on a D2 where wires have been tampered with. The problem at the moment is that on the plug on my rear LH O2 sensor (T185) pin 4 is suppose to go to ECM plug C0635 pin number 7. Instead it's going to pin 15. I'm wondering if this is, because this diagram is 03 or that the wire was swapped. However, this particular wire does not look like it's been tampered with.
Old 06-30-2012, 01:20 PM
Or maybe some plugs switch from one side to another. Attached page on the CPU shows pin 7 to be an output for heater on downstream O2, while pin 15 shows to be sensor signal for the upstream O2. I don't think they had two different CPUs.... Do wire colors in harness match drawing?
__________________
Old 06-30-2012, 01:21 PM
Member
no the schematic is right. My helper on the other side of the continuity tester is getting cross eyed LOL. The pin is in the right place.
Old 06-30-2012, 01:23 PM
Senior Member
hmm, pin 15 should belong to the front O2 sensor. the drawing should be right for all D2's up to '03.
have you checked the front wire to see where it goes? perhaps they got swapped at the sensor end?
is that the only one out of place?
__________________
2003 Discovery
120k
Old 06-30-2012, 01:24 PM
Senior Member
ahh good to hear.
jon
__________________
2003 Discovery
120k
Old 06-30-2012, 01:30 PM
the most dangerous of electrical helpers is the color blind one.....
__________________
Tags
2003discovery, 22003wiring, diagram, discovery, ecu, electrical, fuel, gems, hacking, ii, inline, land, landrover, library, pdf, rover, system
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013 vBulletin Solutions, Inc. All rights reserved.
Emails Backup
