D2 auto shift quadrant mod
Old 12-29-2009, 12:57 AM
Baylink's Avatar
Default D2 auto shift quadrant mod
I thought I'd started a thread on this, but apparently, I buried it somewhere else...
On my '00, the "pull-through" shifts on the autobox are D->3, and 3->D.
This is a bit annoying to me, for 3 reasons:
  • Substantially every other automatic car I have driven in 27 years was R->N->D, D->N,
  • That makes it much easier to bump in and out of neutral without accidentally going into reverse (which I *almost* did, once, while still coasting down, but I luckily have good reflexes, and
  • The manual *actually suggests* that you idle at stoplights in Neutral.
So, given that, has anyone had their shifter quadrant apart *far enough* to know what the plate which controls this looks like, and would it be possible to machine a replacement that would make it shift in the expected fashion?
The FMVSS on automatic transmissions is 102, but it specifies only the order, not which stops must require an extra action (push button, pull column shifter towards you).
Old 12-29-2009, 01:12 AM
Baylink's Avatar
In related news (as I reread the AT section of the RAVE), if you've ever felt like your 4-speed auto has 6 or 7 gears...
remember a) that it has a lockup torque converter, so you'll feel it going from "4th into 5th"...
and that it backs the engine torque off slightly before a shift (I can often feel this happening in both the 1-2 and 2-3 shifts).
razorbak
10-05-2020 02:41 PM
shark19
09-22-2008 09:23 PM
dodge_mich
03-02-2008 07:30 PM
felipenaves
03-20-2007 01:37 AM
Quick Reply: D2 auto shift quadrant mod
