Driver's Door Lock Not Responding
My driver's side door lock is not responding to ANY of the automated locking mechanisms: speed related, remote, OR inside lock button. I can unlock with the door handle, or with the key, but it will not function otherwise.
Is this an easy fix, or am I stuck with taking it to a dealer?
RE: Driver's Door Lock Not Responding
Getting to the place to look at is a pain. With time and a cold one. (only one) it can be done. gaining access to evaluate the problem is the tough part. I could be as simple as a loose or corroded connection. I you go for lay out your parts in the way they came out. Make putting it back together easier. digital/other pictures help. Make sure you secure the window in the closed position when working inside the door. duct take it good. Just some thoughts. Hope it helps. Gotta love a rover. duboff
jfall
04-12-2012 03:26 PM
