Electric fan - Land Rover Forums - Land Rover Enthusiast Forum
Old 08-06-2008, 10:42 PM
Senior Member
Default Electric fan
is it worth replacing the pully-powered fan (Disco 1) with an electric unit? i thought the removal of the drag may increase usable power/improve efficiency.
Old 08-06-2008, 10:46 PM
Senior Member
Default RE: Electric fan
Do you off road? If so then no, you will overheat. The electric fans dont pull enough air.
Old 08-06-2008, 10:54 PM
Senior Member
is it better to replace the pulley powered fan with a aftermarket pulley powered fan?
Old 08-06-2008, 10:57 PM
Senior Member
No, just replace your viscous clutch when it goes bad. You should be able to spin the fan freely by hand.
Old 08-06-2008, 10:59 PM
Senior Member
ok thanks because i was thinking of doing that but wasn't sure about the electric switch or not.
Old 08-06-2008, 11:01 PM
Senior Member
There is no electric switch on a viscous fan clutch, it is controlled by a bi-metalic spring. When it gets hot it locks the clutch. The clutch is filled with liquid.
Old 08-06-2008, 11:07 PM
Senior Member
no sorry what i ment is that i was thinking of switching to a electric fan but didn't know if i wanted to and then i wanted to replace the stock fan but didn't know if it would be any better.
Old 08-06-2008, 11:13 PM
Senior Member
Ok, I think we are on the same page now.
Thread Thread Starter Forum Replies Last Post
Viscous Fan clutch swap for an electric fan?? juan59324 Discovery I 19 02-10-2017 12:08 PM
Electric Fan only comes on with A/C not by temp. Does the Coolant Temp Sensor signal the rad fan? twilightcall Discovery II 13 08-14-2012 05:45 AM
Electric fan to replace clutch fan D1 Scharfire General Tech Help 10 07-24-2012 10:19 PM
Electric Cooling Fan Running vonfonk Discovery II 1 05-06-2006 07:50 PM
Electric Fan mikemeyer0 Discovery II 2 03-30-2005 04:12 PM
Tags
1996, conversion, coupling, disco, discover, discovery, elecric, electric, fan, fans, ii, land, replace, rover, viscous
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
