Electric Power Steering Retrofit
Ok, so I've never really touched the steering system other than replacing track bar and pittman arm. I know exactly jack about Has anyone retrofitted electric power steering to a Disco? How bad of a job would this be? I'd probably be using junk yard parts off of other vehicles, so any tips for what to look for would be great. My only real reason for doing this is that I'm trying to get as much stuff off of the serpentine belt as I can. I'll be doing the same with electric fans and an electric water pump as well as probably removing the A/C compressor.
Hydraulic Electric steering. Where to begin.
It's not goin to be purely electric, you need a hybrid system. It's basically just an electric pump that pumps when needed, so there is also a reservoir and accumulator. The units I work with are way to expensive to justify, and work on CAN, and require a 40 amp circuit. The easiest way I would imagine would be to have a small pump and accumulator with a pressure switch that operates to tell the pump to kick on.
Saturn Ion column.
Then there is a seller on ebay that sells a system to adjust the sensitivity (Saturn Vue ion Chevrolet Equinox ? Electric Power Steering Controller Box ? Epas | eBay).
Install and done.
Install and done.
Saturn Ion column.
Install and done.
Install and done.
electric power steering is 8 times easier to turn. There is literally no effort when it's boosted all the way up.
The only reason I would say no to electric p/s on an offroader, is that there is a major lack of feedback to the wheel. Kinda "vague" for lack of a better term.
I'm gonna have to disagree with you there.....
I came across that kit in a post somewhere where it was retro'd onto a Unimog....so I think it can handle a Rover just fine.
Also, I offroaded my RRC with 33"s and no PS (With the BMW M52 engine swap) and it wasn't difficult. I look like Popeye now though.
Discovered the linked kit and Saturn Ion method when researching ways to retro PS into the RRC....ended up making the OE fluid system work with some custom lines and a bracket.
As for easier to turn, I guess if you have a disability and need zero effort that's a different story.
I've never found myself thinking the PS pump not up to the task with 32" tires.
But everyone has different priorities. When I'm mulling over how to do something mine is (especially for off-roading) KISS, which goes back to the more points of failure.
ambishop
02-09-2007 03:07 AM
