Extra cooling upgrades for the D2? (Towing and pulling grades)
#41
Nevermind. I literally read it four times before I posted that to make sure and somehow missed it all four times.
Have you checked to make sure nothing is in your lines? I think it was Charlie saying he once pulled acorns or something out of one of his rad hoses. Fell in one day when he was doing some work
#42
i just replaced the hoses last week. I was waiting to finish the head gasket job and was moving to the inline stat so did a full flush st the same time.,
i've been playing around with using lower gears while climbing. It seems to help a little.
#43
acorns in the lines? That reminds me of having to pull apart the new samsung washing machine to find a washer neatly blocking the drain pump.
#44
#45
Thats what i'm thinking. Allisport is one of the more well known rover v8 and diesel motorsport manufacturers.
#47
#48
I will wait for Robert's response as I am looking at the stock radiator replacement. My goal is to get the truck back to as if it just came off the show room floor. Of course, if the price is right that could change.
With that said, always feel free to ping me with any of your OEM parts that you plan on replacing (i.e. radiator mounts)
#49
i remember reading about that experience on this forum
i have no doubt that an electric fan can work, it's just my preference to run a viscous fan. I'm curious though, was the spal blocking airflow through the grille to the radiator? The viscous should not be a factor in cooling at highway speeds right?
However in the TX Summer months it would run constantly and on the highway I guess it's air flow rating was poor as anything pass 55MPH = temps would climb until the 237F range and at that point a LR would have toasted, but the 5.3L survived.
stuck the old stock setup on and bingo temps in the normal range. Maybe a more powerful efan would have fixed it, but after spending nearly 600.00 I called it quits!
#50
