Fault code P0125
Old 12-22-2007, 04:30 PM
Nitro96's Avatar
Default Fault code P0125
96 Disco 140,000 miles. Weather has changed, gotten a little colder. Now I have a check engine light with a P0125 code any help out there?
RT
Old 12-22-2007, 05:06 PM
okdiscoguy's Avatar
Default RE: Fault code P0125
Is your truck warming up? Temp gauge should be around halfway up. This is your code....
P0125
Generic
Insufficient Coolant Temp For Closed Loop Fuel Control
Old 12-22-2007, 05:18 PM
Nitro96's Avatar
Truck warms up fine, qauge is up to normal temp in approx 1 mile of driving.
Old 12-22-2007, 05:56 PM
You have a bad coolant temp sensor and your engine is unable to get out of closed loop, running very rich and getting bad gas mileage.
Old 12-22-2007, 06:02 PM
Nitro96's Avatar
Not to argue the fine points but gas mileage has not suffered. Thanks for all the feedback guys, I will change the temp switch and see how that goes.
RT
Old 12-22-2007, 06:41 PM
sideburns's Avatar
throw a thermostat in it and clear codes
Old 12-22-2007, 08:23 PM
ORIGINAL: sideburns
A t/stat will not correct a fault for a failed coolant sensor!!!
Old 12-22-2007, 08:25 PM
Check this site, they have your sensor for $34.
Old 12-22-2007, 08:27 PM
ORIGINAL: Nitro96
RT
With that fault code and your sensor out, you are running in open loop and the ECU has no way to set timing or air/fuel mixtures, your mileage can't be that good and the good news is it will get better.
BG Simons
06-09-2015 11:42 AM
discosophy
04-17-2011 11:43 PM
kaz
05-13-2008 09:10 PM
apcollin
12-05-2007 09:53 PM
Quick Reply: Fault code P0125
