Flashing M and S green lights on dash????
I drove today from Houston to Atlanta where will be for a few months and near the end of the drive the green M and S lights on the dash came on flashing green and also the D next to the odometer and the red light indicator next to the gear shift were flashing.
I had to drive a few miles through a narrow construction zone before I could stop and I put it in park and shut it down. When I restarted it all was ok.
Any thoughts on this? The car ran fine and had no other problems.
Thanks
Thanks
Thanks! The battery connection could well be the issue. While working on my Disco last week I noticed that the positive cable seemed loose and when
I went to tighten it it didn't seem to help and actually twisted on the terminal. I'll either torque it down a little more or replace the cable clamp if it is bad but a momentary loss of DC power could be the cause. The battery is a big one and less then a year old and I am having no issues with starting the car.
Friendly bump.
I am having the same issue. Just one of many from this used 03 Disco Ive bought. I had the battery checked, but only when off. It has 568 crank amps, it was at 100$ charge, and 13.18 volts (or very close to that).
Ive cleaned the terminals, the pos has some corrosion. That seemed to have fixed it for about a week, now it does it all the time. Turning it off, then restarting it sometimes works, but it locked me out once doing that. Wouldnt turn over at all. It seems that when I take off the pos from the battery, resetting the computer, it will be ok for a few days, then starts again.
One thing I did notice, is on the negative lead to the battery, there is what looks like a ground, that is not hooked up. The connection looks like it was in use, because you can see a washer mark on it, where it had some use. But I cant see where it goes. Its about 3 inches back from the end of the cable, where it connects to the battery, and there is nothing there to connect to.
Anyways, this has become a fairly annoying problem. Any suggestions would be great.
I had the same problem and the battery and all the cables were fine. Check your XYZ switch position and make sure that it is tight and in place. Sometimes it gets loose and/or A/C tubes condensation drops into it causing you to lose power and be stuck in 3rd gear. Before I always had to park my car facing out so I never had to reverse, because whenever I reversed and shifted back to drive, the flashing "M" and "S" would start.
