Freeing up Secondary Air Pipe
Old 10-29-2007, 05:31 PM
ajh's Avatar
ajh
ajh is offline
Default Freeing up Secondary Air Pipe
Any tricks to getting the nut holding the secondary air injection pipe to the head to release? A mechanic who worked on it a few months ago cracked the pipe and did a temporary fix which has now failed so I need to get it off the engine tonight so I can braze up the crack he caused. It's cracked along the bottom so fixing it in place isn't really an option.
I've tried putting a wrench on the fitting coming from the head and another on the large nut, I've tried to move it both directions, they're just don't seem to want to move at all and RAVE has the ever enlightening directions of "remove nut holding pipe to head fitting".
Any help would be appreciated.
Old 10-29-2007, 07:49 PM
ajh's Avatar
ajh
ajh is offline
Default RE: Freeing up Secondary Air Pipe
Well, had to give up. The other side wouldn't let go even when I managed to get one to turn. Did external wrap patches for now, hopefully they hold until I'm able to ditch the SAI entirely. Those pipes aren't cheap.
Old 09-12-2011, 08:42 AM
Blackrhino's Avatar
5th Gear
What do you mean 'ditch entirely'
Old 09-12-2011, 09:05 AM
drowssap's Avatar
lots and lots of heat
Old 09-12-2011, 11:45 AM
souljad9's Avatar
I think it was an 18mm open wrench that you put on the square head of the adapter. Use that to hold it straight, and then use another wrench to loosen the nut.
Old 09-12-2011, 07:03 PM
borchera's Avatar
Default Freeing Secondary Air Pipe
I had this same issue and found a crows foot on the SAI tube (threaded into the head) held it put while loosing the SAI nut.
See this thread for an image of the crows foot and the process used.
https://landroverforums.com/forum/di...anifold-43451/
2003 Discovery - High Mile Service complete!
Old 09-12-2011, 09:28 PM
Rovin4life's Avatar
Hit the nut with an impact chisel and loosen it up. Then back it off. We do it all the time in the dealer and it works perfect.
haleyrover
06-23-2011 07:52 PM
ROVERTECH15
04-10-2010 05:04 PM
John Doud
03-25-2010 08:22 PM
isofast
01-31-2010 01:23 PM
dillhole
06-03-2008 02:20 PM
Quick Reply: Freeing up Secondary Air Pipe
