Front End noise/vibration at 50 - 60 mph - Land Rover Forums - Land Rover Enthusiast Forum
Old 11-05-2007, 04:47 PM
samue23's Avatar
Member
Default Front End noise/vibration at 50 - 60 mph
Hey guys,
Took my truck in for noise/vibration in the front end, they said it was wheels out of balance. Two weeks later I'm still getting some vibration in the front end. It actually sounds like a low tone harmonic imbalance/droning with some vibration, any ideas? i am going to make another appointment and take them for a drive with me.
Old 11-05-2007, 05:03 PM
Senior Member
Default RE: Front End noise/vibration at 50 - 60 mph
Well, could be tires, but if that's fixed I'd bet you've got u-joints going bad. Do a search about front driveshaft u-joints on here and you'll see it's very common. And, if not fixed, can destroy your undercarriage, t-case, transmission and anything in it's path. Get your u-joints replaced. Could be front diff, but u-joints are the best bet and if wasn't that, it's maintenance that needs done anyway.
[align=left] [/align]
Old 11-05-2007, 05:27 PM
samue23's Avatar
Member
Thanks Jdelp, I will put that on the list of considerations.
Old 11-05-2007, 06:52 PM
Don't put it on a list of considerations, crawl under the truck and see if your 2 rear u-joints, on the front drive shaft, that attach to the t/case have grease fittings, if not get them replaced ASAP and make sure the rest of your u-joints get lubed at least every 12,000 miles.
By the way, if it is the 2 u-joints and they fail, which they all do, you will be looking for a new tranny afterwards.
Old 11-06-2007, 06:10 PM
samue23's Avatar
Member
ok, Disco Mike
I will let you what I find under there.
Old 11-07-2007, 01:37 AM
Member
Yea I will tell you from experience altough my last U joints failed less than 5k miles ago. I was lucky and no damage done to the transmission th first time the u joints went.SoI just put in a low mileage driveshaft and thought it will be good to go for a couple thousand mileswell sure enough 5k miles later I am looking for another driveshaft and a transmission now . Anyone have any cheap ones PM me.
Old 11-07-2007, 07:22 AM
Senior Member
Another cheap driveshaft? You sure about that?
Old 11-07-2007, 01:42 PM
Member
Well this time I am going to put new greasable u joints in it. The sad part is I had the u joints sitting in my garage the whole time I just figured the driveshaft didnt have but arond 30k miles on it so it should last longer than that before I put new U joints in it. But oh well guess not.
Old 11-07-2007, 01:54 PM
Senior Member
Ouch, that would makeme pretty sad. I had never heard of anybody actually breaking their shaft even though I hear it happens all the time. I thought about putting mine off for a while, thinking that it should be good for a while longer. I'm glad that I did it,even though I didn't really have the time. It's interesting because a lot of 4x4's use this same design with sealed bearings but never seem to have problems. I guess it's just in a bad location on a LR.
Old 11-11-2007, 05:44 PM
samue23's Avatar
Member
Mike,
I went under the truck and just like you said, the two Front U-Joints on the TC do not have grease fittings, Why is this?[:@]
The Roto Flex Coupling had some small cracks in it also.[:@]
So from the looks of things I need to replace the two U-joints at TC with units that have grease fittings and also the Roto Flex Coupling. I can get the U-Joints from Advanced for 15 bucks a piece. I will just have to find someone to install them, should I have them all greased when I install the additional two at the TC? Can I get a Roto Flex Coupling from online, the dealer would probably be too much, yes?
The front U-Joint has a grease Fitting, the Rear U-Joint has a grease fitting and so did the rear drive shaft?.
I tried to upload pics but it didn't work, sorry.
Thread Thread Starter Forum Replies Last Post
Help ID vibration/noise @40 MPH - 50 MPH Disco 2 dirtbag General Tech Help 11 06-03-2015 08:51 AM
Vibration at 73 mph? ljdiscovery Discovery II 36 11-29-2010 12:32 PM
Vibration @ 30-40 then again @ 65-75 mph... MuddMouth Discovery II 4 10-11-2010 10:13 AM
03 RR - front end noise adn vibration bhorwhat Range Rover 1 10-04-2008 09:35 AM
2001 Discover II SE, Vibration at 60-70 mph garywinans General Tech Help 1 07-27-2007 09:07 AM
Tags
2006, 50, 60, colorado, end, front, isuzu, land, lr3, mph, noise, range, rover, suspension, vibrates, vibration
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
