front and rear bumper trimming/rocker panel plastic removal
anyone done this or anything like it? my plans are to trim the lower corners below the fog lights off of each side of the front bumper (only reason being that's the most common rub spot), remove the plastics from the rocker panels, and trim the corners of the rear bumper that hang down. the red line in the pictures will probably explain it better. haha has anyone done this or anything like it? i personally think it will look a lot cleaner and it will also have less plastic to break in the woods.. plus i just dont like having all the plastic
positive feedback only please..
For DI guys, trimming the front bumper is very common, so you might see more examples if you search there.
I've never seen the area below the doors trimmed, as there isn't a whole lot of room to trim, plus it seems that if you trim there, you would lose your splash guard, and you'd have issues with wet roads kicking up water inside. Maybe I'm way off. I've got rock sliders and they are great, they work great and offer a step for the wife.
The only time I've seen the rear quarters trimmed is when a steel bumper (Like a Greg Davis or Rovertym) is added.
I say more power to you, just measure twice, cut once
I would say trimming the rear bumper lower section would be a good idea. You might want to buy a Dremel MultiMax. Great plunge oscillating tool. It will cut plastic cleanly.
I have one and have used it a ton of times, for car projects.
Trimming the rear fender would be a good idea. But you may want to consider a steel wrap bumper to protect lower fender.
I would skip trimming the plastic sides. Save your money for steel sliders.
when my truck was nearly stock i had trimmed the front bumper. i used a sharpened soldering tip. the rear bumper you can trim and the rear quarter panels you can trim (to make it a straight line). the door sills you can remove the plastic trim but i wouldnt cut the metal there.
bcolins
06-22-2013 08:55 PM
