Dead battery doors locked
Old 03-18-2019, 12:31 PM
Ben Matheson's Avatar
Default Dead battery doors locked
Help... WTH never imagined the using the key in the door wouldn't work even with battery dead
Old 03-18-2019, 01:35 PM
The grill is not on the car if that helps me any?
Old 03-18-2019, 01:43 PM
cfz2882's Avatar
can you get at the starter motor to connect a charger and get the battery charged back up? Didn't know a dead batt can cause a lock out-assumed was just a mechanical linkage..My disco came with a damaged spare door-will have to examine that mechanism...
Old 03-18-2019, 02:41 PM
Jumper box on starter worked like a charm
Old 03-18-2019, 05:02 PM
Llamasayswhat's Avatar
The key in the door should unlock regardless of voltage.
Unless you 1)super locked the vehicle or 2)the lock is non-op/broken
Old 03-18-2019, 05:53 PM
You sure? Car was not super locked that I'm aware and key functioned normally prior to this. I ask because using the key in the door never felt like there was enough resistance to be moving anything mechanical.
Old 03-18-2019, 09:31 PM
mln01's Avatar
No.
The lock is not (directly) mechanical.
The only thing the key does is close an electrical switch that grounds a circuit, which in turn signals the BCU to activate the door unlock motors. Insufficient voltage = no door lock or unlock.
Lisa Bunch (03-20-2019)
Old 03-19-2019, 04:20 AM
JUKE179r's Avatar
Damn good idea!
Old 03-19-2019, 12:27 PM
akrover90's Avatar
the pin may have snapped? It is a pretty common problem. Door lock should definitely work with a dead battery.
https://landroverforums.com/forum/pr...ock-pin-82291/
Old 03-19-2019, 12:58 PM
Nope see above......
Quick Reply: Dead battery doors locked
