Fuel Filter 2001 Discovery II
RE: Fuel Filter 2001 Discovery II
I am having a problem with my DiscoII. It is also a 2001. The service engine soon light has been going on and off and the engine will shake or miss slightly. I changed the spark plugs and checked all the wires. I hooked up a code reader and it said the cylinder number 6 multiple missfire detected. Ive also run fuel system cleaner through the system several times. Under load the problem is more apparent and it occurs less often as rpms increase. Makes me think fuel starvation. What do you think?
Same issues, except code for #4 cylinder
Just joined!!!
I have been having the exact same issues as disco2adam. Except my code was for the #4 cylinder. I know you said the #6 is common, do you think that new wires would solve this one too? I just cant get past thinking its a fuel problem.
Thanks for the help.
2001 Disco 2 SE7 Stock 100k
Several problems and STILL in love...
Just joined!!!
always start a new thread when you have a question. and yes if you don't have 8mm wires and descent plat plugs in there you can have misfires. you can also get misfires from the head gaskets failing if you have not already done them as i see you are near 100k.
tolia5
01-21-2011 12:29 PM
