Brake Rotors
Old 01-22-2009, 10:17 AM
DiscoRom's Avatar
Default Brake Rotors
If I replace the r/f brake rotor, do I need to replace the l/f rotor as well?
Old 01-22-2009, 10:19 AM
lrd2's Avatar
Default RE: Brake Rotors
its better to relplace in pairs
Old 01-22-2009, 11:32 AM
YUP
Why are you replacing the r/f? Did a caliper get stuck, what brand of rotor and pads are you going to be using?
Old 01-22-2009, 11:54 PM
DiscoRom's Avatar
Yeah Mike, I think so. The inner 80% of the rotor is the only surface touching the pad.
Original LR rotors and pads would be better if I can get one locally.
The independent rover mechanic said the rotor can be machined to level the surface.
bcolins
09-14-2015 01:10 PM
BmanRRT
07-09-2007 06:03 PM
hoberock
05-29-2007 03:35 PM
fire1427
05-26-2007 09:20 AM
jstreet
07-04-2006 03:36 AM
Quick Reply: Brake Rotors
