Fuel Pump Problem??
Fuel Pump Problem??
Ok, so I just bought (with-in the past week) my first Land Rover, and we are not getting off to a good start. Its a 1997 Discovery 1, and this weekend while driving is started "missing" and acting like it was not getting enough fuel. I took it to a mechanic (non-dealer) today, as I have no Land Rover experience, and he told me it was definately the fuel pump because after testing they were only getting around 8 psi. After reading the repair manual this evening I came across the fuel pump relay, any chance that if this was bad it could cause the same problem or am I stuck with the expensive repair for the fuel pump? I appreciate any input you guys could give me.
Pull out the fuel pump and housing, replace the "pump" with a new Airtek from Autozone or your favorite auto parts store or ebay, and drive. Look for threads on this, there may even be a sticky on it. I did it in my DI and it has worked great ever since. I have a DI '99 with AEL so a new pump and assembly was some $450, the replacement Airtek pump was some $80 if I recall correctly. Good luck. Phil
There is a write up under the "How To" stickie. I was reading through it the other day and it will walk you through the entire process. It was for a '97 Disco so it will be exactly what you are up against. Antichrist suggested an AC Delco EP241 for the pump. I just looked one up using google and looks like it will run you 80.00. He also gives the part number for the strainer if you need it too. Good luck.
on
The VIN is how they determine if it is AEL or non-AEL. I have an "early" 97 that was manufactured in 96. It is non-AEL. Which means you can buy the entire fuel pump assembly (like in the second picture) from Rovers North, their ProLine version for $105 , the rubber gasket is another 13 or so. That's what I did, and it is an exact drop-in unit. The AEL version is much more.
