Fuel Tank Flush Write up?
Old 04-25-2015, 04:14 PM
MPDano's Avatar
Default Fuel Tank Flush Write up?
Hello all,
New here and was wondering if there is a good write up on dropping the fuel tank to clean it out. Was going to get my moms 2000 DII started but it hasn't been started in about 8 years.
Also, any special tools to replace the fuel filter?
Any suggestions would be greatly appreciated.
Thanks,
Leo
Old 04-25-2015, 06:14 PM
Originally Posted by MPDano
Hello all,
Thanks,
Leo
I don't know about the V8 but removing the tank of the TD5 was no picnic as the plastic tube fuel lines had worn through for the 3rd time so I syphoned as much diesel out as possible and dropped the tank but it was mega heavy even with it a quarter full. The TD5 fuel filter is located on the frame behind the rear passenger side wheel but no doubt different on the V8 but the diesel filter is a screw on canister type like an oil filter.
Old 04-25-2015, 06:48 PM
Kenso's Avatar
Fuel filter is integrated to the fuel pump, a screen on the pump pickup basically. The pump itself may be bad after sitting that long too, not uncommon in a situation like that.
Old 04-27-2015, 07:25 AM
MPDano's Avatar
Great info guys. Is there an access area from the top for the fuel level indicator (or internal pump)? Like a panel. If so, any special tool or bolt size. Going to bring some basic tools over to my moms and want to make sure I have what I need.
Thanks again!
Old 04-27-2015, 07:37 AM
drowssap's Avatar
there is access under the rear carpet
Old 04-27-2015, 07:39 AM
MPDano's Avatar
Perfect. Any special tools?
Old 04-27-2015, 07:56 AM
drowssap's Avatar
nope, these picture from google may help: https://www.google.com/search?q=disc...ed=0CAgQ_AUoAw
Old 04-27-2015, 08:57 AM
MPDano's Avatar
Perfect! Looks like 4 screws and all the lines are clips.
Thanks for this.
Old 04-27-2015, 06:32 PM
MPDano's Avatar
Found out the hard part is actually getting to the access panel. Had to remove both panels on the sides. Found my issue. 2 prehistoric mice.
Actual problem was the hoses on the internal pump were brittle and broke off. You can also see the housing coming off the electrical wires too.
Sourcing a replacement pump now.
Question: Is this a "non" secondary air injection model? How do you tell?
Attached Thumbnails Fuel Tank Flush Write up?-20150427_125456.jpg   Fuel Tank Flush Write up?-20150427_125502.jpg   Fuel Tank Flush Write up?-20150427_125507.jpg   Fuel Tank Flush Write up?-20150427_125515.jpg   Fuel Tank Flush Write up?-20150427_125524.jpg
Fuel Tank Flush Write up?-20150427_125528.jpg   Fuel Tank Flush Write up?-20150427_133330.jpg   Fuel Tank Flush Write up?-20150427_133335.jpg   Fuel Tank Flush Write up?-20150427_161204.jpg
Old 04-28-2015, 11:11 AM
MPDano's Avatar
Quick Reply: Fuel Tank Flush Write up?
