Grrrr... Starting issues
Old 07-30-2015, 03:34 PM
pb&jnyc's Avatar
4th Gear
Default Grrrr... Starting issues
My '00 Disco would crank and crank and not start. Garage eventually (and perhaps accidentally) figured it was a key fob issue. I simply used the second set key. So car started and ran for a few days. Now key goes in, dash lights up but won't even turn over. After several tries - usually storming off in anger - car starts and runs fine.
Thoughts?
Old 07-30-2015, 05:42 PM
cappedup's Avatar
First off check battery voltage. Low V can cause all kinds of odd gremlinesque things. I would imagine a garage would do that, but I'd want to know myself.
Then I'd be checking the wiring at the starter.
Old 07-30-2015, 10:03 PM
pb&jnyc's Avatar
4th Gear
That's interesting - the starter was replaced by the garage as they wore it out dealing with the key fob issue. Maybe a loose wire?
Old 07-30-2015, 11:29 PM
cappedup's Avatar
Maybe a defective starter. Not out of the question.
So, goes into a garage, they swap starter, you change a key and it starts?
Come out, stops starting intermittently?
I would defo double check starter/wires.
Main ground points. Learn where they are, remove, clean, replace.
There isn't an imobiliser chip in the key, (as I understand, others can confirm) so if it turns and engages the starter that's all it does.
I know it's been in the hands of 'professionals', but start with the obvious. Don't assume they got anything right.
Old 07-30-2015, 11:41 PM
Charlie_V's Avatar
Also check the battery terminals. Are the cable camps tight? I'd also check the grounding strap at the top left of the engine (drivers side, top corner of engine). If the strap is broken or the nut holding it to the body are loose, strange things can happen. Finally, disconnect the battery and follow the major cables to be sure the insulation is okay. I was driving down a two lane highway in the middle of the night and my truck went DEAD when the wires fell on the exhaust and grounded...zip tie to the rescue.
If you take the starter off, most starter and alternator shops will test it for free, but what a pain on the butt.
Old 07-31-2015, 06:59 AM
And consider the CPS which is the most common cause for starting a D2 has.
Old 08-05-2015, 06:51 PM
pb&jnyc's Avatar
4th Gear
So took it back to the garage that did the work. They could not duplicate the problem. Started and ran for three days - I've had it for a few days and has been starting up without any issues
lazerbrains
LR2
38
08-09-2023 07:54 PM
puppy
11-14-2010 03:40 PM
jrsherfy
08-24-2007 05:47 PM
clacaria
03-18-2007 03:26 PM
mbroker
Freelander
11-24-2006 10:26 PM
Quick Reply: Grrrr... Starting issues
