Has Anyone Used Mityvac for Brake Bleeding?
Has Anyone Used Mityvac for Brake Bleeding? Now Which Motive Adapter to Use on D2?
I'm looking for a good one-man brake bleed kit for my '03. Has anyone used a Mityvac with success? What is your experience and is there anything I should watch out for? Is the optional brake bleed kit necessary or would one of the tubes that comes with the Mityvac fit the bleed nipple?
Thanks.
Alan
Thanks.
Alan
I've used the Mityvac bleeder, and it works OK. The down side is that you are sucking the caliper piston back while pulling fluid through the lines with the Mityvac. This makes it hard to get the pedal at the top of it's stroke because it has to pinch the gap between the pads and rotor before developing pressure. A better alternative is a simple hydraulic checkvalve clamped on the end of a rubber tube then pushed over the bleeder screw. As you depress the pedal, the brake fluid pushes the check valve open. When you release the pedal, the check valve seats to prevent air from coming back in the bleeder. Make sure you push the pedal down SLOWLY so the fluid force does not push the tubing off the bleeder while you're in the drivers seat!
Saw one of these bleeders used on TV this weekend. And they show a "European" version.
http://store.motiveproducts.com/shar...unt2=327079415
I considered getting a Motive pressure bleeder. From my research on this forum there is great confusion on which master cylinder adapter should be used on the 2-tab version on D2. Apparently Motive's website lists the wrong part so I'm quite concerned.
Anyone knows the correct Motive adapter number for the 2-tab M/C on D2?
I use the Power bleeder with great success on my D1. Really simple to use. Fill the bottle with brake fluid, pump up the pressure to about 10 pounds and then go to the wheel and bleed it. I use a turkey baster to suck a bunch of the old fluid out of the master cylinder then refilled it with new before I started thinking it would save time. Can't really say for sure whether it did or not. I used a bottle with a magnetic to catch the fluid so I could go work on other stuff while it bled and just check it once in a while to make sure the bottle wasn't full and what color the fluid was.
The European adapter should fit your D2 also.
Yes AK I see the distinction. The Motive website doesn't actually list an "Import" adapter so I think the "Import" adapter is in fact the "Universal" adapter which is listed as the correct one for Disco on their application guide. I just checked on my other late model european vehicle and the cap is different from the cap of the D2 so I'm pretty sure the Motive Euro screw-type cap won't work on the D2.
If I don't see any positive response I'll probably open a new thread and ask specifically if anyone has used a Motive on a D2 without modification and if so, which adapter was used.
