Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > Discovery II
Register Forgot Password?
Old 01-29-2012, 12:13 AM
Member
joking41
Angry have some questions
okay i got a 2000 disco 2 been doing work as i can. alright i got like 10 codes got most of them sorted but few i wana ask about. during cold start it runs and when driving cold the 3 amigoes will flash for about a block then i regain power. between my 95 and the 2000 my 3.9 has atleast 2x's the power. i cleaned the maf, replacing upper plenum gasket soon this week. autozone says im having missfires so hoping upper plenum gasket will fix it was pretty worn when i did the wires. it also has a code popping up of gear 3 incorrect ratio?? i checked my fluid levels every week due to a power steering leak. the tranny has fluid it drips from the fill level screw hole. another thing on the tranny is low gear when i shift to low gear a light starts blinking with a buzzer on the dash 2 gears with a cross inbetween but low gears engages???? suggestions please comments welcomed opinion awsome. im starting to get a little frustrated with the 2000. but loving my 95. so its a love hate relationship.
__________________
2000 land rover discovery 2/ 125k
1975 honda gl1000 cafe racer /69k
Old 01-29-2012, 09:03 AM
Send a message via Skype™ to Disco Mike
You might stop what you are doing and send me your number so I can call and walk you thru what to do. You most likely have already killed your MAF that will normally not take to being cleaned.
__________________
Mike
Retired service manager. Member of the Solihull Society, NCLR club, SCLR and Santa Barbara 4 Wheelers.
99 D2, 3" lift, CDL with a Detroit and T.T. lockers, H.D. axles, 4:11 gears, Custom front and rear bumpers, sliders, Warn winch, and 5 HID's.
To Download the RAVE Manual, follow this link http://www.landroverresource.com/
Rover Radio issues or IPOD Adapters http://home.valornet.com/splacket/index.htm
Need Parts?
paulgrant@mac.com, or 203-770-1699
willtillery@roverguy.com, or 434-251-9331
Paul PTSchram 260-804-0458
PM Marty(Drillbit)[url]http://www.landroversonly.com/forums...o=newpm&u=5940
British Parts of Utah, http://www.bputah.com/
Lucky8, http://lucky8llc.com/
Old 01-30-2012, 09:13 AM
Member
joking41
Why can't landrover be easy like honda's and toyota's my 95 gives me no trouble...
__________________
Old 01-30-2012, 09:15 AM
Member
joking41
Message me and ill give u my contact info
__________________
Old 01-30-2012, 09:26 AM
hilltoppersx's Avatar
Senior Member
edtatton
what codes are you getting specifically? are you checking the transmission fluid with the truck running? the warning indicator when going form to hi to lo is letting you know the transfer case is in neutral. it will continue to beep and be on until you are in either hi or lo. when was the last time you changed your platinum plugs and are you running 8mm wires?
__________________
-Ed
99 DII, TF +2" HD & steering damper, TreadWright 265/75/16, ARB front, BritPart rear, Warn m8000 with synth, Columbia Overland gate panel & dual battery tray, Safari snorkel, RoverBones diff guards, RockWare sliders, DieHard Plat Deep Cycle, Chalkboard Headliner, CB, Wilderness Rack, 6 hella 700 ff's w 100w bulbs, 2 hella work lights
93 RRC TF track rod, tie rod & steering damper, TRW rims
Northeast Land Rover Club
www.nelrc.com
Old 01-30-2012, 05:54 PM
Member
joking41
7mm wires since I didn't have enough for some magnacore I have a list of codes for you guys lemme write them down before I do that I don't get the transfer case because low works ove had to use it a few times just beeps tho I checked and regapped the plugs in it they were 7 off from oem specs some even 10 idk what brand this truck is gona become my moms problem its eating up my money n time I have customers cars I work on too so its not easy. Ill list the codes soon they are from the last time I went so they may be different since
__________________
Old 01-30-2012, 06:07 PM
Member
joking41
my last code PULLED BYE "RETARDZONE" p1590, p1300, p103, p105, p107, p0733, p1884, p0102, p0300. 4 or 5 missfire but only on one side of the engine, tranny, rich/lean, rotor sensor? and cam sensor? i don't know guys. only work done so far is wires and 02 sensors before cat backs checked out to be fine! so im frustrated...
__________________
Old 01-30-2012, 07:59 PM
Senior Member
The gears with X mentioned before is transfer case in neutral warning, can be a switch.
Seems like MAF. Consider this from the RAVE:
If the MAF sensor fails, the ECM implements a back up strategy which is based on throttle angle. Poor throttle
response and reduced performance will result.
The MAF sensor can fail the following ways or supply incorrect signal:
Sensor open circuit.
Short circuit to vehicle supply.
Short circuit to vehicle earth.
Contaminated sensor element.
Damaged sensor element.
Air leak after the MAF sensor.
Inlet air restriction.
Resistance in wiring harness causing signal offset.
So if you unplug the MAF sensor it may force truck to use plan B which is based on TPS (throttle angle). Will also help if you get the shop rag out of the air intake (workshop prank), and find any splits in the air duct hose caused by moving brittle rubber around to do other work.
If going for a replacement MAF be sure to match up part numbers for compatibility. And be glad you are not in a D1 (you can buy a D1 for what a MAF goes for). Salvage yard?
__________________
Old 02-08-2012, 11:36 AM
Member
joking41
alright i replaced the maf sensor and boom fixed runs and has lots of power! its a present to my mother now. i have my 95 disco now.
__________________
Old 02-08-2012, 12:08 PM
DiscoRover007's Avatar
Senior Member
Make sure you debrief your mother on the Discovery and make sure she watches the temp gauge like a hawk! Lube the drive shafts for her every few months!
__________________
2003 Discovery II SE
Check out the gallery!
http://landroverforums.com/forum/mem...discovery-522/
Upgrades:
HID head light bulbs
2" Terrafirma shocks and springs, medium kit,
Terrafirma steering damper
Rebuilt Drive Shaft
275/65/18 BFG Goodrich A/T TKO's
Repairs:
New HG, intake, valve cover and exhaust gaskets, new spark plugs, green coolant, transmission service
130,000 miles in the death range and still chugging
Tags
auto, gasket, plenum, range, rover, zone
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
