Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > Discovery II
Register Forgot Password?
Old 01-25-2012, 03:47 PM
Kalel's Avatar
Senior Member
Default Head/Brake Light Issues
Okay, just doing a shake down after my off road adventure, and found some light issues. One the low beam headlights are not working. They worked before the trip and afterwards, we went to dinner, and then one went out now both are out. High Beams work fine.
Brake Lights: This apparently was happening before the trip, no one told me though. With the lights on, I depress the brake pedal, the 3rd brake light lights up and the main lights go dim. But when not depressed they shine bright, kinda like they are working backwards.
__________________
Donny
2003 Discovery, CDL,Front Drive shaft, 245/75/16 Definity Mud Tires, Optima Red Top Battery. Vice President Georgia Bounty Runners. 95% done with the Major High Mileage Service.
Old 01-25-2012, 10:32 PM
Senior Member
Fuse 10, inside fuse box, right hand low beam. The real low beam, not the 5 watt city light bulb.
Fuse 9, inside fuse box, left hand low beam.
Beyond that it is bulbs, wiring, switch, etc. All in the RAVE electrical manuals.
Page attached for brake lights, sounds like grounds disturbed, possibly trailer light connector in right rear corner of truck (inside behind cover), pehaps the sockets in the lamp housing.
__________________
Old 01-25-2012, 10:33 PM
Kalel's Avatar
Senior Member
I keep forgetting I downloaded RAVE. Thanks SB.
__________________
Donny
Old 01-26-2012, 09:32 AM
Send a message via Skype™ to Disco Mike
Also, you may have just burned out your low beam, it happens. If that is the case, replace both head light s so you will have the same color and brightness from both sides.
For the 3rd. brake light, try cleaning out the light socket, water can get in there causing corision.
__________________
Mike
Retired service manager. Member of the Solihull Society, NCLR club, SCLR and Santa Barbara 4 Wheelers.
99 D2, 3" lift, CDL with a Detroit and T.T. lockers, H.D. axles, 4:11 gears, Custom front and rear bumpers, sliders, Warn winch, and 5 HID's.
To Download the RAVE Manual, follow this link http://www.landroverresource.com/
Rover Radio issues or IPOD Adapters http://home.valornet.com/splacket/index.htm
Need Parts?
paulgrant@mac.com, or 203-770-1699
willtillery@roverguy.com, or 434-251-9331
Paul PTSchram 260-804-0458
PM Marty(Drillbit)[url]http://www.landroversonly.com/forums...o=newpm&u=5940
British Parts of Utah, http://www.bputah.com/
Lucky8, http://lucky8llc.com/
Old 01-26-2012, 08:27 PM
Kalel's Avatar
Senior Member
3rd brake light works, but when the lights are on, the L/R brake lights go dim when depressing the brake pedal. And get real bright when not depressed. Kinda like they are wired backwards.
__________________
Donny
Old 01-26-2012, 09:36 PM
Senior Member
Pull this connector and check: (see attached)
pin 1 = green white = turn signal
pin 2 = ground
pin 3 = red / black = tail light (or red / orange, depends on side of truck)
pin 4 = green / purple = brake
Or maybe some one installed incorrect bulbs and jammed them to fit.
__________________
Old 01-27-2012, 06:49 AM
Junior Member
Hello buddies,
I have some problem with my rare brake lights. I didn't understand the problem. How can i check it out? I need your help
__________________
life insurance texas
Old 01-28-2012, 10:22 PM
Kalel's Avatar
Senior Member
Both fixed, somehow I blew both front headlights one right after the other. And the rear started working correctly after I took the bulbs out a re-installed them. Thanks for the help.
__________________
Donny
Tags
2003, brake, discovery, forum, high, issues, land, light, lights, located, problems, range, rangerover, rover, stop, tail
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
