Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > Discovery II
Register Forgot Password?
Old 01-23-2012, 08:56 AM
Member
Default Head Gasket Question
I'm leaking coolant out of the back side of the p/s head looks to be precisely between the head and the block. No smoke, but it leaks pretty good. I have to fill the reservoir up once every other day, and I only drive about 20 miles round trip. It's a constant drip while the engine is running and at operating temperature.
I'm assuming it's the head gasket, but I've never seen one blow out where it doesn't leak into the oil or the cylinder. I'm assuming that this is possible, though? are there any other possible solutions?
Old 01-23-2012, 08:59 AM
Junior Member
I had the same problem with my car and i did whole head gasket job. It was really leaking from head gasket and also if it is closer to the driver's side, it might be water pump seal. In my case those two were constantly leaking and all the time there were drops under the car and I had to add at least half of the bottle every 3-4 days.
__________________
Land Rover Discovery II 2001, Color - blue, Interior - tan, Mileage - 85K, Name - Blue Stallion
Old 01-23-2012, 09:16 AM
Send a message via Skype™ to Disco Mike
There are many ways a head gasket can fail,
coolant leak to outside of the engine
coolant leak into the crank case
oil leak to the outside of the engine
exhaust leak to the outside of the engine
exhaust leak into the coolant system
Plus any other combination, in other word you don't need to have coolant to have a failed head gasket.
__________________
Mike
Retired service manager. Member of the Solihull Society, NCLR club, SCLR and Santa Barbara 4 Wheelers.
99 D2, 3" lift, CDL with a Detroit and T.T. lockers, H.D. axles, 4:11 gears, Custom front and rear bumpers, sliders, Warn winch, and 5 HID's.
To Download the RAVE Manual, follow this link http://www.landroverresource.com/
Rover Radio issues or IPOD Adapters http://home.valornet.com/splacket/index.htm
Need Parts?
paulgrant@mac.com, or 203-770-1699
willtillery@roverguy.com, or 434-251-9331
Paul PTSchram 260-804-0458
PM Marty(Drillbit)[url]http://www.landroversonly.com/forums...o=newpm&u=5940
British Parts of Utah, http://www.bputah.com/
Lucky8, http://lucky8llc.com/
Old 01-23-2012, 09:21 AM
Member
Thanks, Mike.
Looks like I'm replacing a head gasket!
Good thing I parked it last week then. It's amazing....68k on the clock and a blown head gasket....gotta love discos!
Old 01-23-2012, 09:30 AM
That is about the normal time for them to first fail, along with plug wires and the front drive shaft.
__________________
Mike
Need Parts?
Old 01-23-2012, 06:14 PM
Senior Member
It seems that between 70-90k miles everything except the seats needs to be rebuilt or replaced.
__________________
2004 Discovery SE - TerraFirma 3" Lift w/ TF Steering stabilizer, TF rock slider w/ trees, TF diff guards, TF wheel spacers, Nitto Trail Grappler MT 285-65-18 LT tires, BajaRack w/OEM ladder, Tactical Rovers front winch bumper w/ Engo 9000S
**Awaiting install: Fox 2.0 Resivoir Adj shocks, RTE adj Panhard, TF HD Steering rods, Columbia Overland 1" spacers
Addiction fed by: Justin @ Lucky 8 LLC & Eric @ Tactical Rovers
Tampa, Florida
Old 01-23-2012, 06:59 PM
Senior Member
here's a pix of the back of head leak
__________________
Old 01-23-2012, 08:08 PM
G Reeves's Avatar
Senior Member
My cylinder HG went at 55K
__________________
new PWR St pump, KN panel filter, magnaflow back box, coil conversion, 90k service, HG done at 55k, Okib' pads front and rear
Member of North Wales Land Rover Club
LR Scrutineer
90k + ticking mile
2003 Disco 2 SE
2002 Volvo V70XC... SWMBO
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
