Head gasket replacement and what else?
Great advice man. I had the intake and valve covers cleaned(in a parts bath and ultrsonically) while the heads were being re worked. I did notice the screws on the interior of the valve covers and will clean those and replace what needs replacing on that. Thanks for that idea and keep em coming
good luck!
Hate to start the oil debate again but need advice
Gunk....the engine degreaser. I'll spray the entire engine when I get it all together. I got the intakes and a few pulleys and the valve covers powdercoated in black wrinkle which looks like line-x so I don't want to mess that up but i want the rest of the engine nice and clean. Previous took good care Maitenance wise but not astestically under the hood. I'm gonna use some royal purple hps oil for the first few oil changes to help get the internals clean that I couldn't get clean. I got the caps of the pistons done today with a rag, pb blaster n elbow grease. I hate to start an old war but I'm looking at using royal purple hps 10w-40 and I know a lot of people use rotella 15w-40. Please elaborate on the purpose of using this diesel oil instead of a regular Dino oil or a royal purple synthetic hps with a high zzdp content. I hate to start the debate but just wanted some good info. I did order so magnecor 8mm plug wires and debating on using what type of plugs. I'm not looking at the bosh platinum +4 but a conventional gapped plug just because of all the dang ethanol. Also what is the size of bolts for the back of the cylinder head on the passenger side that the lifting plate hooks too
Just south of bham. Smack dab in the middle between bham and montgomery. The bham one has been keeping some in stock recently. I was actually able to get all new rear ac vents and some sunroof motors that look like they never were used. I keep a check to see if they get a 2004 so I can get the cdl cable. But I'm look for a new center console in bahama beige or black with the tabs still in tact for the switches. I've done a fix with epoxy and sheet metal now but I'd like one in pristine condition.
