Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > Discovery II
Register Forgot Password?
Old 02-01-2012, 06:29 PM
jrover99's Avatar
Member
Exclamation Help!!
My discoII has 175000 miles on it how long should a head gasket last mine was done at 94000 miles but I think the truck needs a tune up i smell gas when it is cold and when the truck warms up it is good..Please let me know i really cannot afford to do head gaskets again.. thanks
__________________
99 Disco II
Old 02-01-2012, 07:34 PM
Philip Lawrence
Send a message via Skype™ to Spike555
Sounds like you need a tune up.
I was told recently by a Rover tech that as long as you keep the PCV system clean the headgaskets should last forever.
__________________
www.marshill.org
Walk by faith not sight.
The "Storm Trooper", 1997 Discovery with 212,000 miles.
www.20liters.org
Old 02-01-2012, 09:30 PM
jrover99's Avatar
Member
Question Pcv
Leaving the rover overnight at my mechanic so he can start it first thing in the morning to see what he thinks. I am hoping it is just a tune up. What is the PCV not to sound stupid on this.. Thanks
__________________
99 Disco II
Old 02-01-2012, 09:41 PM
Philip Lawrence
The Positive crankcase ventilation is on the passenger valve cover and it goes to the intake plenum.
Remove the hose from the valve cover and inside the valve cover is a weird looking thing, pull it out and clean it with carb cleaner, do this every 6 months.
That is the PCV system on these trucks.
Basically what it does is it sucks the gases and water vapor out of the crank case and routes it to the engine to be burned.
If it is clogged pressure will build up inside the engine and blown gaskets and seals.
__________________
www.marshill.org
www.20liters.org
Old 02-01-2012, 10:03 PM
jrover99's Avatar
Member
Question Ok one more thing?? Water sound?
I don't know if it's just me, When I come to a stop I feel water moving, its sought of strange like I am hearing water moving, Any ideas about that as I am a woman and have no idea?? Thanks Again
__________________
99 Disco II
Old 02-01-2012, 10:10 PM
Senior Member
Your truck has no idea of your gender. But you are wise to describe issues with sounds, etc. The water rushing in dash is an indication that there are air bubbles in the cooling system. The heater core (a small radiator) is located under the dash and has coolant circulating thru it all the time, even when AC is on.
Bad thing is that sometimes this noise is an indicator of head gaskets. But, it can also just be air trapped in the system from a leaky hose connection. Mechanic can purge the air from the system. There is a chemical test for "combustion gas in coolant" that can be done that would prove or disprove head gaskets.
__________________
Old 02-01-2012, 10:26 PM
jrover99's Avatar
Member
Wink I knew it was not me!!
I had told my husband and he just giggled about the water in the dash. Thank you so coming up with an explanation for the water, it explains the sound at least. Still pray its not the head gasket.
__________________
99 Disco II
Old 02-01-2012, 10:32 PM
Senior Member
Hearing the water in the dash is just the way most of us know that we need to top off the coolant.
Old 02-01-2012, 10:54 PM
Senior Member
Print the attached drawing out for reference by hub and mechanic. Arrows show direction of coolant (water and antifeeze). Item 1 is the heater core.
__________________
Old 02-02-2012, 09:13 PM
Philip Lawrence
Top off the coolant like was already said, if the "waterfall in the dash" comes back you have a blown head gasket and that would explain the rough running when cold and coolant loss.
__________________
www.marshill.org
www.20liters.org
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
